floor pan? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2009, 06:48 PM   #1
tallgoofy2000
Hillbilly hourse play
tallgoofy2000's Avatar
Default floor pan?
I got my self in to a project cuz i was bored and need the money. it was sapose to cab corners and rockers. when i peeled the carpet back this is what i found.............
dam i think i bit off more than i can chew on this but i got nothing but time. going to wire weel and see what is hiding under the ruber sound insulation tomarrow.
tallgoofy2000 is offline   Reply With Quote
Old December 27th, 2009, 12:19 AM   #2
Yota Bill
I just recently went through the same thing on the same model Ford truck...guy bought the cheapest damn rockers and cab corners he could find, and they didnt even match each other, let alone matching the truck...I ended up making most of the parts myself, and just used the parts he bought to make the outside look right...floor pans I just made myself.
Old December 29th, 2009, 04:58 PM   #3
tallgoofy2000
I have been making sum progress. finally got most of the tar mat on the floor off just the pass. side foot area left, got to dark today. But i did however get the back wall done and cleaned up. He just wanted something to hold and seal the wall into place. (its just a farm truck he dont care) i took 12 ga. and bent a 90 and layed it in and welded it. it dont look to hack but its geting covered with a layer of bed liner when I get it all the holes patched.
Old December 29th, 2009, 11:45 PM   #4
Yota Bill
that box between the floor and the back wall is structural, and so is the pinch weld behind/under it (can see the pinch weld from outside the cab, easily if the bed is removed) you might want to make sure that pinch weld isnt also rotted away, or it will be putting alot more stress on that box then it is designed for...not sure what that would cause, but I'd bet it would eventually rip that box out of the floor, or cause the back side of the box to collapse, taking the back wall, roof, etc with it
Old December 30th, 2009, 03:31 PM   #5
tallgoofy2000
wtf i hate photo bucket you move a few things around and it screws every thing up....
got floor pans from NPD 33 bucks a pice hopefully make sum progress tonight after the kids go to bed.
Page generated in 0.23462 seconds with 38 queries
