Free Selectable locker for a full float axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2009, 11:01 PM   #1
kkodet
kkodet's Avatar
Default Free Selectable locker for a full float axle
I figured this would be a nice place to write up about this.
One of my work trucks is very old and has a weird width Dana 70 rear axle in it. This summer it busted an axleshaft (not abuse, it appeared to have a marble sized manufacturing flaw in the shaft and finally snapped). Much junkyard and internet shopping came up with nothing for a replacement shaft.
The truck is slated to be retired very soon and we didn't want to put any major money into a custom shaft, so I came up with an idea.
I pulled the diff and welded it, as many of you have done before. This prevents the side gears from spinning.
Then I put the drivers side axle shaft back in, being that the drivers side is the side almost always on pavement while driving. Then I took the busted shaft and cut off the shaft section, making a cap for the hub (to keep the gear oil in).
This made the truck a one wheel drive vehicle. I'm not worried about it because it is heavy and is never driven in the winter. With only having one shaft, it is un-noticable that the rear is welded and the truck drives like it has an open diff.
My techs put about 15,000 miles on the old girl this summer with no axle issues. The truck weighs 13,000 lbs loaded.
This got me to thinking. If someone wants to DD a full float rear but has no fat cash for a locker, why not just do what I did, and then swap a pass shaft in when they want to wheel?
I just figured I'd share this idea and let you know how well it worked. I'll probably eventually do this to some low budget rig in the future.
Old December 25th, 2009, 11:06 PM   #2
boggin-machine
boggin-machine's Avatar
+10 hillbilly cred
Old December 25th, 2009, 11:19 PM   #3
94jimmyjr
94jimmyjr's Avatar
sweet
94jimmyjr is offline   Reply With Quote
Old December 26th, 2009, 01:18 PM   #4
95geo
newbie
95geo's Avatar
Driving with one wheel powering the vehicle is not fun.. I've done it and it's almost scary. The longer wheel base probably makes it less noticable but I wouldn't recommend it for anyone who has a dual purpose vehicle.
Old December 26th, 2009, 01:32 PM   #5
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Send a message via Yahoo to Chrisholmz
So, how are the burnouts?
Chrisholmz is offline   Reply With Quote
Old December 26th, 2009, 01:36 PM   #6
IDIeselman
IDIeselman's Avatar
Done years ago in a 78 4x4 f350, With the stock 400, Burnouts were limited only to the driver getting tired of smelling smoke.
Old December 26th, 2009, 03:35 PM   #7
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Old December 26th, 2009, 10:05 PM   #8
kkodet
kkodet's Avatar
Completely un-noticable. I've also done this in my Sami when I busted an axleshaft, and it too was un-noticable. But I guess the sami has a long wheelbase though
If you were getting something scary going on, what was it? I bet it had nothing to do with having one wheel drive.
Old December 27th, 2009, 12:59 PM   #9
95geo
newbie
95geo's Avatar
You could feel the vehicle get pushed side to side by the one driven wheel when power was applied and then when it was compression braking... I had to counter steer slightly to keep from changing directions while driving down the road. The tires had a lot of drag and were at 6psi so that could have been a part of it also.
Old December 27th, 2009, 02:23 PM   #10
pistol pete
I do vinyl stickers
pistol pete's Avatar
i did that with my welded 14 bolt(except i machined a cap for it to keep gear lube in) it drove fine down the road i dove it mostly around town, and yes you could do one hell of a burnout, it was a pain every time i wanted to go wheeling i had to keep putting the shaft back in. so i quit being cheep and bought a detroit locker, the best money i ever spent
pistol pete is offline   Reply With Quote
Old December 28th, 2009, 12:45 AM   #11
Ebs
How about doing the same to a front axle with a two piece axle shaft as a poor mans selectable locker. Disengage the axle when you need to make a sharp turn and then engage the front for maxxx traction. I'm not sure what's out there for a heavy front axle that use a two piece axle shaft...maybe a late model Dodge D60.
Old January 1st, 2010, 10:28 PM   #12
kkodet
kkodet's Avatar
I've thought about this, and I bet it would work fine. In fact I'm going to be trying it soon on my buddys YJ. He wants to weld the front diff and put in a cable actuator. He doesn't do more than mild mud around his farm, so I think it will hold up until I can talk him into larger axles.
Page generated in 0.45291 seconds with 59 queries
