2 barrel to 4 barrel conversion for 1985 dodge ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 24th, 2009, 01:06 PM   #1
redneck942
redneck942's Avatar
Default 2 barrel to 4 barrel conversion for 1985 dodge ram
I am looking to replace the stock holley two barrel carb for a four barrel carb. I am not really certain what I need and do I need a new manifold or is there adapters.
redneck942 is offline   Reply With Quote
Old December 24th, 2009, 01:06 PM   #2
redneck942
redneck942's Avatar
Oh forgot the dodge has a 318 C.I. engine
Old December 24th, 2009, 02:39 PM   #3
dodgeboy
redneck truck club
dodgeboy's Avatar
get a intake. and get it non egr also! its easy and not a bad price either! i went through summit when i did one about a year or 2 ago
dodgeboy is offline   Reply With Quote
Old December 24th, 2009, 02:58 PM   #4
75v8cj
Don't go too big on the carb. Stock motor needs a small carb. The 2bbl you have is prob a 350 cfm. 4 bbl I wouldn't go over 550-600 for a stocker. Other wise it will run worse than with the 2v. The adapters work but you will not get the full advantage of the new carb. 2v has more low end torque than a 4v. 4v with small primaries gets better mileage (if you can keep your foot out of it) and more mid to upper range power.
75v8cj is offline   Reply With Quote
Old December 25th, 2009, 09:16 PM   #5
redneck942
redneck942's Avatar
ok thanks a bunch
Old December 25th, 2009, 09:37 PM   #6
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
agree with above, when i had my 82 ramcharger, i researched this alot. most guys that did this said that it ran best with 550 cfm, don't go any bigger unless you want to do some heads and cam.
big_ol_bronco78 is offline   Reply With Quote
Page generated in 0.20909 seconds with 41 queries
