should i??? 4.2 crank and rods in the 4.0?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2005, 01:25 AM   #1
PolarYJ
Throttle control?
PolarYJ's Avatar
Send a message via AIM to PolarYJ
Default should i??? 4.2 crank and rods in the 4.0??
your call!
PolarYJ is offline   Reply With Quote
Old November 5th, 2005, 08:16 AM   #2
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Strokers do run great than built right. Go for it!
Old November 5th, 2005, 08:29 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
Sounds like you will have more power then my baby small block
Old November 5th, 2005, 05:24 PM   #4
PavementPounder
PavementPounder's Avatar
http://www.jeep4.0performance.4mg.com/stroker.html
Old November 5th, 2005, 08:58 PM   #5
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I'm building mine now. I dropped everything off at the shop today to get the block, head, crank and rods machined. I'm expecting about 200HP/265f/lbs at the wheels when its done.
For added power, try to find an intake of a 99+, they are twice the volume and are good for almost 20 horse on a 4.7
Blue XJ is offline   Reply With Quote
Old November 5th, 2005, 09:21 PM   #6
Chop
Mischievous Badger
Chop's Avatar
i like the idea for a stroked 4.0 but i cant deside to do that or a SB, price wise
Old November 6th, 2005, 09:17 AM   #7
Blue XJ
The Green Machine
Blue XJ's Avatar
If you have to build the small bolock then a stroker will be cheaper. If you are just buying one and dropping it in, then it may not be too bad. The stroker will probably give you more torque though.
Old November 6th, 2005, 10:21 AM   #8
C.K.
Dont Feed the Cyco
C.K.'s Avatar
And with a stroker it all fits without a bunch of other mods. I'm hoping to do a stroker next year. Thanks for the link PavementPounder.
C.K. is offline   Reply With Quote
Old November 7th, 2005, 08:31 AM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Yep I am in the process of a stroker for Kim's jeep as well. It is a wise decision with no mods to be done to your rig to install, other than motor mods.
Old November 9th, 2005, 03:11 AM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Stroke it Jay !!! i really dislike the idea of a small block in a jeep !
When u go to do become real good friend with somone in machining and have it bored for free !! Aw hell tear it down this weekend and ill machine it out in the next couple labs !
Old November 10th, 2005, 01:11 AM   #11
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
you don't have to bore it or really do any machining on it (unless it's damaged or out of tolerance of course). If you use the stock 4.2 crank throw and the 4.2 rods the piston actually sits lower in the cylinder (not much lower at all, but still lower). So bore wise it shouldn't be a problem. On the other hand, the older 4.2 crank might need some grinding and of course bearings. Aside from that, I think there is little machining that would need to be done.
Page generated in 0.18265 seconds with 56 queries
