Vinyal Printing/Cutting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2009, 06:15 AM   #1
BlaineWasHere
GVSU Jeeper
BlaineWasHere's Avatar
Send a message via AIM to BlaineWasHere
Default Vinyal Printing/Cutting
I am looking into getting the equipment to print my own vinyl stickers. Example would be the single color stickers you peel off and put on your car. I'm don't need "high volume" equipment or a printer that really is wider than 12-16" or so. We have some "high volume" machines at work and it seems simple, it feeds in the vinyl, the software paired with the printer "etches" the vinyl, you pear the design and then put it in a sticky clear back, then put backing paper on it and BAM! vinyl sticker. Idealy I would like to run this printer/software with my 15" macbook.
Thanks for the help anyone can offer!
BlaineWasHere is offline   Reply With Quote
Old December 21st, 2009, 10:59 AM   #2
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
you want a cutter/plotter. many companies sell cheap ones for the hobbyest.
you put your cast or calendered vinyl in there, it cuts the design, you weed off the waste, apply your premask, etc.
you will have to understand vector paths fairy well in a keyline format to do anything complex and have it look nice. beginners fail because they are looking at composite previews and not the lines that the cutter will cut. usually what happens is the cut paths overlap and make a shitty decal.
Old December 21st, 2009, 12:51 PM   #3
BlaineWasHere
GVSU Jeeper
I get the whole idea of vectors, I used to use them in totally unrelated work on photo shop.
I just need hobby level equipment. Next step for research?
Old December 22nd, 2009, 11:53 PM   #4
BlaineWasHere
GVSU Jeeper
bttop
Old December 23rd, 2009, 04:02 AM   #5
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
Start small...get a cricut.
yellowjeeperman is offline   Reply With Quote
Old December 24th, 2009, 08:47 AM   #6
Muttly
Muttly's Avatar
Start here:
the vinyl stock come in 24" standard rolls, buy at least a plotter/cutter that will handle 12" stock.
Muttly is offline   Reply With Quote
Page generated in 0.18700 seconds with 40 queries
