94 Intrepid 3.5HO Engine codes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2009, 07:41 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 94 Intrepid 3.5HO Engine codes
any body have a scanner to read check engine light for a 94 intrepid.
Silver Bullet is offline   Reply With Quote
Old December 18th, 2009, 07:52 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
yep
Old December 18th, 2009, 10:07 PM   #3
hamsmotorsports
hamsmotorsports's Avatar
got one pm me if you wanna drive it over i will scan it
hamsmotorsports is offline   Reply With Quote
Old December 22nd, 2009, 12:43 AM   #4
sonic
sonic's Avatar
autozone does it for free and i can shoot you the diag
sonic is offline   Reply With Quote
Old December 22nd, 2009, 01:57 AM   #5
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
For a '94? Shouldn't that be grounding pins? Hence 96+ was OBD 2...
NSmist is offline   Reply With Quote
Old December 22nd, 2009, 09:16 PM   #6
dodgeboy
redneck truck club
dodgeboy's Avatar
94 should be a key on and off some many times and watch the light blink. count how many times for the number of code.
dodgeboy is offline   Reply With Quote
Old December 22nd, 2009, 11:11 PM   #7
Flat_Black
The Dodge Guy
Flat_Black's Avatar
key on off on off on. this link is for the trucks but is the same for most chryslers http://www.dodgeram.org/tech/gas/Tro...fault_code.htm
EDIT: here is a list for 94 chryslers http://autorepair.about.com/library/...htm?once=true&
Old December 28th, 2009, 03:44 PM   #8
Silver Bullet
codes 12, 21, 55.
What do 12, 55 actually mean.
11 IGN reference signal.
12 Battery input to PCM disconnected during last 50 key starts.
13 MAP sensor pneumatic circuit.
14 MAP sensor electrical circuit.
15 Vehicle speed/distance sensor.
16 Open or shorted condition detected in knock sensor circuit.
17 Engine running too cool.
21 Oxygen sensor circuit.
22 Coolant temperature sensor circuit.
23 Intake air temp. sensor voltage high.
24 Throttle position sensor.
25 IAC motor driven circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
32 Fault in EGR diagnostics.
34 Speed control solenoid circuits.
33 A/C cutout relay circuit.
35 Fan control relay circuit.
41 Charging system excess or no field current.
42 ASD relay circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
45 Overdrive Solenoid open or shorted
46 Battery voltage too high.
47 Battery voltage too low.
51 Oxygen feedback system stuck at lean position.
52 Oxygen feedback system stuck at rich position.
53 Internal logic module problems.
54 No cam position signal.
55 Completion of fault code display.
62 Indicates unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
64 Methanol sensor voltage too low.
Old December 29th, 2009, 07:49 AM   #9
Silver Bullet
come on guys.
i either have a bad miss or slip that is not consistant. Also on take off with a heavy foot it usually boggs real bad (sometimes it doesnt and will spin the tires 10-15'). The other day the trans would not engage into gear (I had to rev the engine up and down to get it to engage). After it did engage it would not shift beyond 1st gear. When I drove home from work that night it was fine. Yesterday it wouldnt shift into overdrive so the first light I shut the car off and restarted it and all was fine.
Would any of these codes be causing the trans to lock up? Also what causes the bogging/miss. 3.5 H/O motor.
Old December 29th, 2009, 06:55 PM   #10
Flat_Black
The Dodge Guy
Flat_Black's Avatar
code 12 might be a bad o2 sensor or broken wire. the bog could be to much fuel due to the o2 sensor. you might try running a higher octane gas and some octane boost to boot to see if you can clean out the o2 sensor. code 12 is in the last 50 times the car has been started the battery has been disconneted and 55 is no more codes. the catalytic converter might be bad also throwin the 12 code.
Old December 29th, 2009, 07:10 PM   #11
xjmichigan
xjmichigan's Avatar
That motor required 89+ octane.
Old December 29th, 2009, 08:31 PM   #12
Silver Bullet
The battery has not been disconected. What else could cause that code.
alan,
Come over and take a ride.
Old December 29th, 2009, 08:31 PM   #13
xjmichigan
xjmichigan's Avatar
k
Page generated in 0.33342 seconds with 62 queries
