WJ Grand Cherokee 4" X-Series Lift Kit! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old December 18th, 2009, 06:09 PM   #1
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Default WJ Grand Cherokee 4" X-Series Lift Kit!
Rough Country puts the “Grand” into Jeep Grand Cherokee with their new 99-04 WJ 4” X-Series Lift Kit. This kit comes complete with front coil springs, front disconnects, and Rough Country’s premium 2.2 shocks for both the front and rear. A new heavy-duty front adjustable track bar is also included in the 99-04 Jeep Grand Cherokee 4” X-Series Lift Kit. Designed with a heim joint, this track bar adds strength and flexibility to your WJ without limiting suspension travel. Rough Country finishes up the kit by including two front adjustable X-Flex control arms with X-flex joints for improved articulation and enhanced off-road performance. The addition of Rough Country’s 99-04 Jeep Grand Cherokee 4” X-Series Lift Kit will leave you with a great looking, trail ready rig.
Includes front coil springs, front lower adjustable control arms with X-flex joints, front sway-bar quick disconnects, front bumpstop spacers, front adjustable track rod, transmission crossmember spacers, rear coil springs, rear upper control arm brackets, rear bumpstop extensions, rear sway-bar brackets, rear shock relocation kit [Keeps shocks clear from tires], and hardware.   Includes (4) Performance 2.2 series shocks.
Benefits:
  • 100% bolt-on installation
  • Increased ground clearance
  • New X- Flex adjustable control arms
  • Features Premium Application Valved Performance 2.2 shocks
  • Lower control arms provide proper offset to allow for wider tires
  • Kit maintains stock alignment for precise high speed handling and proper caster/pinion alignment
Accomodates 265/75 tires on factory wheels.
$749.95
Need it installed? We can do that for you in OUR OWN shop!
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Thread Tools
Page generated in 0.26929 seconds with 26 queries
