draining auto trannies - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2005, 05:07 PM   #1
Bones
Bones's Avatar
Default draining auto trannies
i've heard of people disconnecting the cooler line, then running the motor. any other tricks?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 28th, 2005, 05:10 PM   #2
bigblue2230
still goin
bigblue2230's Avatar
well i've never heard of that trick, but it sounds painful unless you are hooking it up to a flush machine.
bigblue2230 is offline   Reply With Quote
Old November 28th, 2005, 05:16 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you get some hard plastic air line like for a air brake system in a truck you can slide it down the dip stick hole and suck the pan dry without burning up the trans. I used a salvaged hydro pump from a convertable top. works great for any oil up to engine oil. they won't move gear oil though. the other pump to use is a electric diesel lift pump from a 24 vavle cummins. it will real move some fuel or other thin liquids. it has a built in strainer so you have clean it once in a while.
Yetti
Old November 28th, 2005, 05:20 PM   #4
Bones
Bones's Avatar
well once the pan is pulled, how do you get all the fluid out?
or just pull the pan, change the filter, reinstal, and call it good?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 05:38 PM   #5
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
I've always loosened the pan to drop one side more than the other and used a basic drain pan. Sometimes a little gets by to the floor, but thats what floor dry is for.
Old November 28th, 2005, 05:39 PM   #6
Bones
Bones's Avatar
so basically you guys don't fully drain the clutch packs, valve body, Torque converter, etc?
you only drain what is in the pain?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 05:43 PM   #7
clarkstoncracker
lol
clarkstoncracker's Avatar
I would suggest tapping/plugging your pan for making life easier down the road too.
Old November 28th, 2005, 05:44 PM   #8
Bones
Bones's Avatar
yup, already picked up the B&M kit, although i bet this means I never change the filter lol
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 06:03 PM   #9
dirt714
fawkin' noob
dirt714's Avatar
I always think of it like this.... Why change the fluid without changing the filter? If you do routine maintenance and change your filter every 60k or so, droppin' the pan every 30k is more than enough to keep your fluid clean and operational.
Also listen to Yetti. I've got a hand pump that I use for coolant drains and trans drains. Slip it right down the dipstick tube. Or tap the pan . I like that idea.
dirt714 is offline   Reply With Quote
Old November 28th, 2005, 06:26 PM   #10
Bones
Bones's Avatar
do you do it with the trans running?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 06:53 PM   #11
xjmichigan
xjmichigan's Avatar
why is everyone making this so hard?
1. buy 3 or 5 gallons of fluid( or buy it in quarts and put it all in one big clean bucket
2. disconnect the lower (or what ever draws fluid back to the trans)
and place it in the bucket (you may need to extend the line)
3. disconnect the line that goes to the cooler and let that empty on the ground, your neighbors grass or anotherbucket.
4. start it up, cycle it through all gears few times, you may want another person to tell you when the bucket it almost empty, re hook up all lines.
5 drop pan, change filter, add 4-5 qts of fluid.
Old November 28th, 2005, 08:27 PM   #12
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Damn pretty much the jist of it. Bones unless you do a flush from the shop the above mentioned is the only way to get most of the old fluid out. There isn't a drain plug on the torque convertor like on fords.
Old November 28th, 2005, 08:28 PM   #13
Bones
Bones's Avatar
yah, this is my diesel though.... its already done though
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 29th, 2005, 04:41 AM   #14
dirt714
fawkin' noob
dirt714's Avatar
6. Smoke your tranny
Old November 29th, 2005, 05:16 AM   #15
Yetti
Yetti's Avatar
no , not nessaraly. the idea is sound, but the mess more then makes up for the little work involved. we have big flush machines at work that do the same thing. it does it with the engine OFF. we never flush with the engine running, its just to chancy to blow up a trans that may have cost a $100,000.
do it how you see fit, but you can add an external filter to the cooler line for little money and be twice as safe.
Yetti
Old November 29th, 2005, 08:08 AM   #16
xjmichigan
xjmichigan's Avatar
how would you smoke the trans? maybe if your a compleate moron
Old November 29th, 2005, 10:35 AM   #17
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The hardest part about smoking a trans is getting it lit first.
Old November 29th, 2005, 11:08 AM   #18
xjmichigan
xjmichigan's Avatar
Old November 29th, 2005, 01:39 PM   #19
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
But the buzz is worth the hassle. :miff:
FrankNBrew is offline   Reply With Quote
Old November 29th, 2005, 05:21 PM   #20
kevp77
I break it!
kevp77's Avatar
Send a message via Yahoo to kevp77
All in all ... take it in and get it done ... boom done
kevp77 is offline   Reply With Quote
Page generated in 0.70107 seconds with 83 queries
