TJ cage question - Dash bar - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2009, 09:50 PM   #1
srlbotanical
Because I Said So...
srlbotanical's Avatar
Default TJ cage question - Dash bar
97 TJ - Adding to the existing OEM stuff.
I'm tied into the frame below the A pillar, going up through the dash and tying in the existing A to B cross pieces that attach to the window. I am going across the top of the window with tube and I would like to put a piece of tube across the bottom of the window.
Here's my questions:
- how much room do I need between the dash and that lower window tube in order to take the dash off again in the future. (without cutting off that bar)
- How much does a dash bar restrict the defrost. I live in Michigan and I'm a mouth breather so...
Thanks in advance.
Steve
srlbotanical is offline   Reply With Quote
Old December 17th, 2009, 07:47 AM   #2
redmud
10 0011 10101
redmud's Avatar
Mines' pretty tight to the dash, and what I did was take the two screws out of the center stack before I welded in the bar- but I put them back in, as they are removable when the windshield is down. I'll get an exact measurement later today if you want.
The defrost works fine, my bar is a touch behind the vents, and I can still get the center strip doohicky out with the windshield down.
redmud is offline   Reply With Quote
Old December 17th, 2009, 07:51 AM   #3
redmud
10 0011 10101
redmud's Avatar
Here's one from the other side:
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
Old December 17th, 2009, 08:52 AM   #4
srlbotanical
Nice - Thanks for the pics. If you get a chance, a measurement would be great.
Old December 17th, 2009, 10:23 AM   #5
redmud
10 0011 10101
redmud's Avatar
In the center, over the center stack, I have 1/2", and it's @ an 1/16th of an inch from touching the backside of the IP.
BDS Suspension
Old December 17th, 2009, 10:25 AM   #6
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I think it is about 3/4" You need to be able to lift the piece up to allow the clips to release.
cvwindows is offline   Reply With Quote
Old December 17th, 2009, 10:33 AM   #7
redmud
10 0011 10101
redmud's Avatar
Mine comes out with no clearance issues, except the part where I have to tilt the windshield down to get to it.
BDS Suspension
Page generated in 0.20131 seconds with 44 queries
