round 2 - 2nd set of 1 tons in my Jeep, more beef!!! - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2012, 10:54 AM   #61
Originally Posted by 1TFROT View Post
surprised the R&P let go. I'm running a yukon r&p in my d60 and it's held up great to some serious abuse. running 42" SXIIs on H1 double beadlocks (very heavy!) and a healthy 6.0 (r&p is 5.38)
jeep looks good. have fun with the new rubber
you'll love having the 14 bolt rear. you'll never worry about it. mines spooled and has upgraded 1541 shafts.
Never say never.
Day 2 at Moab.
Old March 25th, 2012, 11:13 AM   #62
1TFROT
1TFROT's Avatar
Never say never.
Day 2 at Moab.
ok, ok... ALMOST never have to worry about
fins and things, moab, 2wd
I know they are not bulletproof and anything can break, but they sure hold up to way more than they probably should. sorry to hear about your carnage on a trip like that.
1TFROT is offline   Reply With Quote
Old March 25th, 2012, 01:12 PM   #63
The good side? The carnage wasn't me.
This was the view outside my window.
Old March 25th, 2012, 05:57 PM   #64
Eric99tj
Just bump it....
Eric99tj's Avatar
Do not lower your skidplate!! I got mine to fit after I knocked up the floorboards a little bit with a BFH.
Southern Michigan Rockcrawlers
Eric99tj is online now   Reply With Quote
Old March 25th, 2012, 07:30 PM   #65
akozman
Chrome Trucker Chicks Rul
akozman's Avatar
Maybe you will be able to keep up now.
When's the first outing?
says the old man who is gonna need a cane soon
how heavy are you wheels/tires, mine weigh in at 175 or 185 each can't remember for sure.
I think the locker broke and took out the R&P, but might as well go with more beef if I have to replace the R&P up front....I'll have even more confidence running 10.5" R&P front and rear , icing on the cake to me is that it's an HP front end still, I would't have done it with a LP front end.
I was thinking that too, gotta pull the case back out and put the floor jack under it to see if the floor will move that way otherwise the BFH will come out of hiding (already did that for the old 231 case). I have a JK case and it's much hornier than a TJ version, all sorts of ding dongs sticking out for reinforcing, I'll have to cut a few down.
akozman is offline   Reply With Quote
Old March 25th, 2012, 09:57 PM   #66
1TFROT
1TFROT's Avatar
203# each
Heavy Sob's
My rig is kind of a fatass too
Old March 26th, 2012, 05:01 PM   #67
liv2mx
i like jungle gym's.
liv2mx's Avatar
so what year jk is your case? i heard they dont fit well in a tj and they are different is this true? you have to modify anything? i have been bidding on 3 different tj rubi cases but if the jk one is the same i will do that.they seem to be easier to get.
Old March 26th, 2012, 06:50 PM   #68
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I think its all operator error!!!
cvwindows is offline   Reply With Quote
Old March 26th, 2012, 08:41 PM   #69
benny87
Young Gun..!
benny87's Avatar
I figured with your fancy rig you would have updated to a better t-case...
benny87 is offline   Reply With Quote
Old March 26th, 2012, 11:07 PM   #70
akozman
akozman's Avatar
ditto
I have no clue what year the JK case is. I started with a TJ case that had both halves broken to pieces (looked like a front end wreck type of damage) but all internals were fine. JK's use a tone ring so the rear tail cone section is different on a JK, all I did was swap the rear cone section from the TJ case onto the JK case halves I got and all is good. All I need to do is trim a few of the casting nobs down to clear my floor board better, but no real mods at all. It's no Atlas but for the price I can't go wrong. Added a Teraflex 2low kit while I was rebuilding it.
I'm not certain if the JK main shaft is the same length or not as a TJ, if it is you "should" be able to pick up the rear tail cone and wheel speed sensor parts from a TJ at the dealer (or JB maybe) and swap those onto the JK case.....but I can't confirm this, I'm sure JB could if they wanted to
Old March 26th, 2012, 11:11 PM   #71
akozman
akozman's Avatar
this is a TJ case rear section
JK case rear section - you can see the big nobs I was talking about
Old March 27th, 2012, 07:52 AM   #72
liv2mx
liv2mx's Avatar
i like the rubi case.it has some beef, 32 spline outputs and 4.1. you guys can keep your loud ass, hard shifting, oil leaking atlas...that is 1200 bucks more and only 26 spline stock front output...(unless you got the upgrade)
if i break this i will have a 205 in it.
Old March 27th, 2012, 09:26 PM   #73
akozman
akozman's Avatar
with that attitude you'll never be cool enough to suck off Tim Cameron
Old March 27th, 2012, 09:33 PM   #74
liv2mx
liv2mx's Avatar
he dont like those there atlas boxes eather ya awl..there going to a solid tractor case or back to a 205....so suck on that there tid bit you damn yankees..
he has broke 2.plowboy has broke more then i can count.scott from sunfire has broke 6 or 7. and those are the cases with all the good stuff.scot went through 3 4 speeds and the rest have been 2 speeds.
thanks for the info on the case.i am hoping it will work for a while.
Old March 27th, 2012, 09:59 PM   #75
akozman
akozman's Avatar
no sweat, Atlas is to rich for my blood too and this case was a steel and definetly provides some beef (I even got an extra front output shaft on the deal). One thing I was thinking about the JK Case since it does not have a speed sensor the shaft just might be different or you may have to drill a small hole to retain the speed sensor if the shaft is the right length if you want a speedo....see this pic, the tiny little retaining pin. i'm guessing a JK doesn't have this pin since it's a tone ring on the axle.
I stole these pics from this dudes write up on
Naxja
good info in it.....I'm way to impatient to take pics like this while working, I just put the shit together and go, pics after it's done.
Old April 15th, 2012, 10:34 PM   #76
akozman
akozman's Avatar
slow progress.....lied about my last statement pics with the phone otherwise to lazy to go in and get a real camera
T-case is in, air hammered the snot out of the floor board to make it fit as good as possible. new cross member to seperate it from the skid plate. Rear axle is all tacked up.
Next up pull the fuel tank to notch it out for the 14 bolt and start on the front end.
Old April 23rd, 2012, 10:22 AM   #77
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nice brackets!
Old May 30th, 2012, 01:00 AM   #78
akozman
akozman's Avatar
slow progress, but slammed a bunch out in the last week. All that's left on the list is rear brake lines, fuel tank mod for the 14b and some other misc doo dads
Jana 76
14B it it's new home waiting for shock brackets and a few things
Jana 76 waiting on ring for diff cover to space it out for the D70 R&P
Sitting on all 4 again
Old May 30th, 2012, 07:07 AM   #79
Gettin there.
Old May 30th, 2012, 09:02 AM   #80
Bleay
sick of jackstand wheelin
Bleay's Avatar
Did you go with the D60 ARB or the D70 for that Jana76?
Bleay is offline   Reply With Quote
Page generated in 0.45883 seconds with 84 queries
