Flat-towing 4x4 chevy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2005, 04:33 PM   #1
amc78cj7
amc78cj7's Avatar
Default Flat-towing 4x4 chevy
Well, sort of. I have a chevy drivetrain in my CJ. 1988 Chevy 700r4 tranny, NP241c t-case. What positions do I need to have the tranny and t-case in when it's being flat-towed? Does t-case need lubeing while spinning? Is removal of rear driveshaft necessary? I have a slip-yoke eliminator on the t-case too so shouldn't have to worry about fluid loss.
I know this subject varies depending on the tranny and t-case models, and I can't find this info in my chevy service manual.
TIA.
amc78cj7 is offline   Reply With Quote
Old November 28th, 2005, 05:22 PM   #2
Bones
Bones's Avatar
just be 100% sure and pull your driveshafts
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 28th, 2005, 06:20 PM   #3
AWK
AWK's Avatar
Trucks -
Four Wheel Drive And All Wheel Drive
"dinghy" Towing Is Permitted On Four Wheel Drive Trucks Only When Equipped With: - T Trucks Equipped With A New Process 231 Transfer Case (rpo Np2) - K Trucks Equipped With A New Process 241 Transfer Case(rpo Np2) - K Trucks Equipped With A Borg-warner 1370/4401/4470 Transfer Case, And The Transfer Case Is Placed In The Neutral Position. - K Trucks Equipped With A New Process 246 Transfer Case (rpo Np8)
In Order To Determine The Transfer Case Model, Locate The Identification Tag. This Tag Attaches To The Rear Case Half And Provides The Transfer Case Model Number (figures 1 And 2). Only Vehicles Equipped With New Process 231/241/246 Or Borg-warner 1370/4401/4470 Model Transfer Cases Can Be Dinghy Towed With The Transfer Case In Neutral.
Important: The Following All Wheel Drive And Four Wheel Drive Vehicles Should Not Be Dinghy Towed Unless The Propeller Shafts Are First Removed.
- K Trucks Equipped With The Optional Electric Shift Transfer Case, New Process 243 (rpo Np1) (no Neutral) - T Trucks Equipped With The Optional Electric Shift Transfer Case, New Process 233 (rpo Np1) (no Neutral) - Syclone, Typhoon, L Van And Bravada Which Are Equipped With The Borg-warner 4472 Transfer Case (no Neutral) And The Nvg136 Transfer Case - T Trucks Equipped With The New Process 207 Transfer Case (no Oil Pump) - K Trucks Equipped With The New Process 208 Transfer Case (no Oil Pump)
The Transfer Cases In These All Wheel Drive Or Four Wheel Drive Vehicles Either Have No Neutral Position Or Internal Oil Pump To Provide Lubrication While Being Towed. To Properly Tow These Vehicles, The Vehicle Should Be Placed On A Platform Trailer With All Four Tires Off The Ground. Towing With All Four Tires On The Ground Should Be Avoided. In Rare Cases When Towing With All Four Tires On The Ground Is Unavoidable, Both Front And Rear Propeller Shafts Must Be Removed In Order To Prevent Damage To The Transfer Case And/or Transmission. Follow The Applicable Service Manual Removal/installation Procedure As Front And Rear Propeller Shafts Are Matched To Attaching Components At Assembly.
TOWING PROCEDURE
THE CORRECT DINGHY TOWING PROCEDURE THAT ALL CUSTOMERS SHOULD FOLLOW IS GIVEN BELOW.
NOTICE: EXTRA CARE SHOULD BE USED WHENEVER TOWING ANOTHER VEHICLE. THE TOWING VEHICLE'S GCWR SHOULD NOT BE EXCEEDED BY ADDING THE WEIGHT OF THE DINGHY TOWED VEHICLE OR VEHICLE DAMAGE MAY RESULT.
1. FIRMLY SET THE PARKING BRAKE.
2. PLACE THE AUTOMATIC TRANSMISSION IN "P" (PARK) OR THE MANUAL TRANSMISSION IN THE LOWEST GEAR (1ST).
3. SECURELY ATTACH THE VEHICLE BEING TOWED TO THE TOW VEHICLE.
4. IF EQUIPPED, PLACE THE TRANSFER CASE SHIFT LEVER IN "N" (NEUTRAL).
CAUTION:
SHIFTING THE TRANSFER CASE TO NEUTRAL CAN CAUSE THE VEHICLE TO ROLL, EVEN IF THE TRANSMISSION IS IN PARK (AUTOMATIC) OR 1ST GEAR (MANUAL), AND MAY CAUSE PERSONAL INJURY.
5. RELEASE THE PARKING BRAKE ONLY AFTER THE VEHICLE BEING TOWED IS FIRMLY ATTACHED TO THE TOW VEHICLE.
6. INSERT THE KEY INTO THE IGNITION SWITCH AND TURN THE KEY ONE NOTCH FORWARD OF THE LOCK POSITION. THIS PLACES THE KEY INTO THE OFF POSITION, WHICH UNLOCKS THE STEERING COLUMN WHILE PREVENTING BATTERY DRAIN. UNLOCKING THE STEERING COLUMN WILL ALLOW FOR PROPER MOVEMENT OF THE FRONT WHEELS AND TIRES DURING TOWING.
AWK is offline   Reply With Quote
Old November 28th, 2005, 11:42 PM   #4
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
you maby should move that to its own topic for a write up thing.
GMCsonoma94 is offline   Reply With Quote
Old November 29th, 2005, 08:09 AM   #5
amc78cj7
amc78cj7's Avatar
AWK, you rock!
Sounds like I should have my 700r4 in Park and my 241c t-case in Neutral. And driveshafts can remain attached.
Thanks a ton!
Jeff
Old November 29th, 2005, 09:27 AM   #6
AWK
AWK's Avatar
Glad to help. Not sure if you have a locking column or not, but added it just in case.
AWK
Page generated in 0.26388 seconds with 41 queries
