1987 Comanche, Rolling w/title - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2006, 01:00 PM   #1
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Default 1987 Comanche, Rolling w/title
This was another GLJT Member's old rig, and while I wanted to finish it up, I have decided parting it out would help out a couple other projects I'm working on.
It currently has a 350 Chevy set up to run on propane, SM465, and a Down East Flipped D300, but I will be using the engine and t-case in other projects. (engine in the '69 CJ6, and D300 with my crawlerbox project)
What is left-
1987 Comanche body with SOA rear, 4.5" lift front (Pix show it with sagged 3" springs with a spacer) Rockers replaced with box tube. Front D30/rear D35 both with 4.10s. (Rear pretty hashed, front with one piece 297x shafts in a disconnect housing) As it sits, it will just barely clear Q78s (lots of fender trimming), and it still will acept a small block chevy. Some rust in the floors and driver's door. The Q78s are not included, but I have some steel wheels with decent roller tires on it. It also has a Harbor Freight winch mounted behind the bumper, but I plan on using it on my trailer.
Price as listed above- $400
I also have a fairly rare AMC M20 from a Comanche, 4.10 gears, factory 1 piece shafts with a 5 on 4 1/2" bolt pattern that I will include for an extra $150 if you buy the Comanche, $225 by itself (I have a Lock Right locker for this rear end that may be available, as well)
Or-
An open 3.54 XJ D44 (I may actually also have an MJ D44 but I would have to check) drum to drum, bad pinion seal. I will include it with the MJ for an extra $210, or $300 by itself
I can bring this to the west side/GR area if needed.
~EDIT- I now have a set of 4 Q78s that I can include with this for an additional $300 if you buy the Jeep. You would still need to swap them onto a set of wheels. (beadlocks aren't included)
Old July 16th, 2006, 12:40 PM   #2
SS
Bananarama!
SS's Avatar
Keep the truck together and I'll trade my 95 Ram for it.
-Jer
Old July 17th, 2006, 01:40 PM   #3
Cooter
Cooter's Avatar
Thanks for the offer, but no thanks.
I'm now planning on using the SM465 with the D300 i the TJ, as I save length with the crawlbox setup.
Willing to start parting it out the rest of the way if I get enough intrest.
Old July 17th, 2006, 09:55 PM   #4
mudslinger101
mudslinger101's Avatar
Default the hood
do you think that hood will fit on a xj, would you be willing to part it, how much.
mudslinger101 is offline   Reply With Quote
Old July 17th, 2006, 10:20 PM   #5
Cooter
Cooter's Avatar
The hood would fit on an XJ- they are the same from the seats forward. I'd take $50 for the hood, but it is just a stock hood with a hole in it and a scoop on it. (The stocker wouldn't clear the propane mixer on the Chevy)
Old July 17th, 2006, 10:51 PM   #6
snocross2xtremes
snocross2xtremes's Avatar
man i want this but my dad would shoot me if i got another jeep lol
Old August 11th, 2006, 04:06 PM   #7
Cooter
Cooter's Avatar
Git Back Up There...
Old November 18th, 2007, 12:57 PM   #8
Cooter
Cooter's Avatar
Top with Edit...
Page generated in 0.29676 seconds with 47 queries
