my homemade mattracks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2009, 10:08 AM   #1
boggi
wen in doubt throttle out
boggi's Avatar
Send a message via MSN to boggi
Default my homemade mattracks
this has been floating through my head for a while, that it cant be too hard to make these mattracks instead of ditching out the money on just an old truck that is used in winter time alot for snowplowing. so here is an idea that i came up with
yay or nay. the pic says it all. the red is a rim that just mounts on your truck like any regular rim, it will have peices sticking off it for the track to grip on to. and the grey is steel supports that will hold it together, do you think that is thick enough what is in the legend? and the blue is just idler[boogy] wheels for the track to ride on
all input appreciated. i got some skidoo tracks at my pops and the steel and the boogy wheels and the rims so i got everything i need, and my pop is a welder
thanks
boggi is offline   Reply With Quote
Old December 11th, 2009, 10:12 AM   #2
Pokerob
hug life
Pokerob's Avatar
looks like it should totally be easy to build
make sure to post pics when you build it so we can make fun of you
Old December 11th, 2009, 10:14 AM   #3
boggi
boggi's Avatar
haha im not sure if ill build it yet, just a maybe
Old December 11th, 2009, 10:15 AM   #4
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
how are yopu going to stop if from just rotating and you dont have nearly enough approach angle
Old December 11th, 2009, 10:16 AM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I wish I had pics, but theres another way. I seen one done years ago for yellowstone tours. it used Bombardie tracks from a Muskat and then used a drive carriage that slid under the whole van. then it drove the two tracks off a gear mounted in place of the rear wheels. in the front it used two huge A arm mounted skies with mounts to the front hubs. it then used a drag link to each ski and the hub as suspension. it was pretty cool and the only thing that was not mounted to the hubs was a crossmemeber added under the trans for mid mount of the craddle assembly. it was totally removable come spring time.
Yetti
Old December 11th, 2009, 10:17 AM   #6
rentalrider
rentalrider's Avatar
Oh yeah, I'm sure it won't offer any challenge. And are you doing this for your atv or truck? I see a HUGE difference. With the weight of a truck putting sheer pressure on bogey wheels (I'm assuming you're talking about snowmachine bogeys) when turning during plowing I'd give it 3-5 turns before shit starts snapping and flying off that thing. But I'd love to be proved wrong as it would be really cool if it worked. Keep us posted.
Old December 11th, 2009, 10:18 AM   #7
boggi
boggi's Avatar
never thought of that but i figure same was as on a quad, just have like radius arms to hold it
Old December 11th, 2009, 10:19 AM   #8
boggi
boggi's Avatar
they would be the steel ones that are sorta like the ones that comes on mattracks, not the plain old plastic snowmobile wheels lol
Old December 11th, 2009, 10:19 AM   #9
Yetti
Yetti's Avatar
if it helps try looking at some of these for ideas
http://www.atvtracks.net/
Yetti
Old December 11th, 2009, 10:19 AM   #10
bj house
bj house's Avatar
That truck was my senior project at WMU! My professors son worked in the park. Our senior design project was to select an efficient torque biasing system so that it would turn better. The way it was then was that it would just brake the inside track in a turn and I guess it pushed really bad.
Oh and I have pics but they are on film and at home :)
Sorry for the hijack
Old December 11th, 2009, 10:21 AM   #11
Yetti
Yetti's Avatar
maybe it would be easier to just buy a used halftrack? their around if you look.
http://www.halftracks.com/index.cfm
Yetti
Old December 11th, 2009, 10:21 AM   #12
rentalrider
One more thing... without some sort of device to keep the wheel from spinning the whole assembly when torque is applied, I think you'd be putting that ski-doo track through your fenderwell.
edit: nevermind, someone beat me to it.
Old December 11th, 2009, 10:22 AM   #13
Yetti
Yetti's Avatar
you sure your talking about the same one? the one I saw was built around 1990
Yetti
Old December 11th, 2009, 10:23 AM   #14
boggi
boggi's Avatar
13 replys in 13 minutes, not bad
Old December 11th, 2009, 10:25 AM   #15
Renegade II
Coil springs are for pens
Renegade II's Avatar
Nay; There's some serious engeneering going on with those things.
http://www.mattracks.com/html/production.htm
Old December 11th, 2009, 10:30 AM   #16
boggi
boggi's Avatar
but you guys should know this is only going under a bronco 2, they only weigh around 3000lbs its not going under a fullsize truck
Old December 11th, 2009, 11:09 AM   #17
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
Originally Posted by mean_greenEXJAY View Post
Those tracks dont look that hard to build yourself. Like they said they just use snowmobile tracks and boggie wheels, it even looks like an off the shelf steel wheel for the drive sproket.
That is what I said in this thread,
Mattracks - anybody seen them? - Great Lakes 4x4. The largest offroad forum in the Midwest
, really doesnt look that hard to do at all.
Old December 11th, 2009, 11:24 AM   #18
Yetti
Yetti's Avatar
Arn't those the ones that would flip over because their center of gravity was to high? and you want to raise it?
Yetti
Old December 11th, 2009, 11:27 AM   #19
BooGTS
Boost Withdrawl
BooGTS's Avatar
MS Paint is a serious engineering tool.
BooGTS is offline   Reply With Quote
Old December 11th, 2009, 11:30 AM   #20
boggi
boggi's Avatar
of course. lol
actually ive owned several and never flipped one and ive never seen one flipped on all the forums im on
this is my newest one, shes much to low, shes getting a 3" body lift and 4" susp and 33s
Page generated in 0.34972 seconds with 83 queries
