need crack welded on alumium jeep t-case. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2009, 07:32 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default need crack welded on alumium jeep t-case.
Brothers 98 grand with the 4.0L has a crack in the t-case. I'm not sure which one it is.... all I know is it has the fluid couplers and part/full time. There is a crack that leaks fluid.
Could someone weld it up for us that is close to Livonia? I'm guessing you just need to drill a hole at each end of the crack to relieve stress?
Old December 10th, 2009, 08:14 PM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
You could probably get away with preheating it and welding it without drilling holes. I could do it but Im a ways away.
Old December 10th, 2009, 08:26 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I think it cracked because the chain stretched. There was wear marks on the inside when we rebuilt it last year. The engine blew so my brother bought it off our friend. It leaked bad.... lol
Old December 11th, 2009, 09:42 AM   #4
PavementPounder
PavementPounder's Avatar
Can't have all that on the same case. You either have a 249 with a viscous coupler and FT only, a 231 with PT and no FT, or a 242 with PT & FT and no viscous coupler.
I don't know that it matters at all which TC you have based on the issue, but make up your mind.
Old December 11th, 2009, 09:53 AM   #5
95geo
newbie
95geo's Avatar
I'd love an excuse to weld more aluminum...
I'm not very close though.
Last weeks fun
Old December 11th, 2009, 10:04 AM   #6
Tab
Tab's Avatar
Last weeks fun
Is that pop can welded to your dash? Because that would be cool!
Old December 11th, 2009, 10:48 AM   #7
95geo
newbie
95geo's Avatar
nope, just fuel for me...
Welding a pop can is extremely difficult, it's about as hard as cleaning the outside to bare metal without denting it. Maybe I'll bust out the .040" tungsten and see if I can weld a pop can still. Might just have to weld it to the dash if I can.
Old December 11th, 2009, 11:11 AM   #8
Swampdog02
Wakley Creek Wacos!
Swampdog02's Avatar
Try
Express Tool & Die Welding
Address:
37050 Amrhein Road
Livonia, MI 48150-1107
I took my aluminum intake to them when it cracked.
They welded it right up on the spot for me, didn't even charge me.
Told me to tell all my buddies about them if they need stuff welded.
I took them a bunch of Doughnuts the next day.
They are really cool, and it's right there in Livonia.
Good Luck.
Swampdog02 is offline   Reply With Quote
Old December 11th, 2009, 11:11 AM   #9
I broke 2 different 231's right beside the front output. First indication was t-case blood on the floor. Added these gussetts & never had a problem since.
By the way, if you think the welds look good, I did them. If you think they look bad, I had someone else do it.
Old December 11th, 2009, 01:04 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
PP: Yes I realize that it does not matter lol. But its like asking someone about their truck/jeep and than they start rambling on what is done to it, when really you don't care.
I will have to check out the place in Livonia. Thanks! Also could you just leave it all together and have it welded?
Thanks for the offer Geo, you are kinda far. Nice looking stuff though
Old December 11th, 2009, 01:12 PM   #11
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Try my Dad, Joe at St. Pierre Inc. 1-248-620-2755. By the way he's in Clarkston.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old December 11th, 2009, 01:21 PM   #12
PavementPounder
Please videotape.
Old December 11th, 2009, 01:57 PM   #13
95geo
newbie
95geo's Avatar
I retract my offer.
Have you ever dropped a pair of jumper cables into a tub of oil? well imagine a huge spark with an instant flame and molten metal popping.... kind of like lighting magnesium on fire and adding in some highly flamable oil.
Old December 11th, 2009, 03:10 PM   #14
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
lol. I guess I never thought of that. I don't claim to have every answer. I guess I thought you could maybe keep it together since its a small crack.
Old December 11th, 2009, 03:43 PM   #15
95geo
newbie
95geo's Avatar
TIG welding is extremely sensitive to outside contamination, TIG welding aluminum is even more so. Any amount of contamination in/on the metal whether it's oil, wax, paint, grease, mill scale, oxidation, you name it, you can notice it and sometimes it really screws up the weld. You actually have to clean aluminum with a stainless steel brush to ensure it's clean enough to get a quality weld on. If you grab a brand new sheet of aluminum and start a bead, the very small amount of surface it has on it is enough to screw the weld up, that's where the stainless brush helps break through that coating. Brake cleaner works pretty well but as you saw with that article a while ago, if you hit a pocket of it, it can just about kill you.
Old December 11th, 2009, 06:22 PM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
ah ok. I had no idea. That article was a great read as I do somtimes use break clean to clean the weld area.
Page generated in 0.36409 seconds with 71 queries
