cutting fenders what should I use? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2009, 12:21 PM   #1
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Default cutting fenders what should I use?
I just got a 91 wrangler last night and the front fenders are beat up pretty bad. I think I want to cut them off like a couple of the jeeps I've seen on here and was wondering what the best way to do this is and what I should use to make the cuts. I really don't want to do a shitty job. Thanks.
lastmanstandin is offline   Reply With Quote
Old December 9th, 2009, 12:25 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
sawzall
Old December 9th, 2009, 12:25 PM   #3
Tab
Tab's Avatar
Grinder with a cut-off wheel and a steady hand. Put a line of tape down and cut through the tape, it will help with the paint peeling.
Old December 9th, 2009, 12:26 PM   #4
fatboy21
Do it in the mud
fatboy21's Avatar
Send a message via AIM to fatboy21
Yeah what he said
fatboy21 is offline   Reply With Quote
Old December 9th, 2009, 12:28 PM   #5
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
I tried using a sawzall once to trim fenders and it tore the crap out of the metal. Cut-off wheel, dremal or shears would work good.
mudviper is offline   Reply With Quote
Old December 9th, 2009, 12:29 PM   #6
fsumotorhead
N8KVB
i've used them a few times with good results, you have to hold the saw firmly against the fender
Old December 9th, 2009, 12:49 PM   #7
lastmanstandin
EvL 1
Thanks guys, me and sawzalls don't mix well so I think I'll try the die grinder with a cut off wheel. What should I put on it after the cut's or should I just paint it and leave it like that?
Old December 9th, 2009, 01:26 PM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
jig saw with a metal blade and tape. for best result leave a 1/2" extra and then bend a lip with the extra.
Old December 9th, 2009, 01:39 PM   #9
lastmanstandin
EvL 1
Not sure if theres enough good fender left to leave a half inch for a lip....I'm going to go check it out right now.....I just got the jeep last night and haven't even been able to go mess with it!
Page generated in 0.23482 seconds with 50 queries
