Straight axle dakota - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2009, 12:49 AM   #1
Jbrandon
Default Straight axle dakota
I have a 2000 Dodge Dakota. Right now i have about 5 inches of lift inluding 3" body a torsion bar crank and 2" rear blocks. . The front has independant suspension and rack and pinion steering. I would like to put full size axles under it probably a 9.25 rear and a dana 44 in front. This is my first build and i need help. Does anyone have any advise on how to do this? Could i use a full size dodge for parts (steering, coils, etc.) ?
Jbrandon is offline   Reply With Quote
Old December 10th, 2009, 10:01 AM   #2
PavementPounder
PavementPounder's Avatar
You could do that, but you'll need to compare the full-size axle's coil bucket spacing to your intended mouting points on your frame and make sure they aren't too far apart on the axle.
I don't know what tire size you are wanting to run, but if you're going to use full-size Dodge axles it will be the same type and amount of work to run the D44/9.25, D44/D60, or D60/D70 combos.
Old December 10th, 2009, 06:56 PM   #3
MedicJayCook
Street Doc
MedicJayCook's Avatar
motorcitydak, has a SAS dakota with coilovers and a hp44/ford 9" and a hemi swap. you should PM him
MedicJayCook is offline   Reply With Quote
Old December 11th, 2009, 08:13 AM   #4
sonic
sonic's Avatar
Check: dakotausa.com great site for dak owners good group of guys
sonic is offline   Reply With Quote
Page generated in 0.26482 seconds with 35 queries
