Electric fuel pump question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2009, 05:33 PM   #1
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Default Electric fuel pump question
I had recently purchased a 79 CJ7 and the previous own had installed a Holly electric fuel pump in it. From looking at how he has it set up, there is no return line back to the tank. From other electric fuel pump set ups I have seen, there has always been a return line. There doesn't seem to be any problems with the operation, so is it necessary to have a return line on electric pumps or not?
Thanks
mudviper is offline   Reply With Quote
Old December 6th, 2009, 05:35 PM   #2
Bishop
Bishop's Avatar
no. you don't need one if done properly.
Old December 6th, 2009, 06:05 PM   #3
mudviper
getting dirty
mudviper's Avatar
I guess my next question would be what is considered done properly?
Old December 6th, 2009, 07:47 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
typically i like to run a return style system because it keeps the pump cooler and it doesn't have to work as hard. you can go without a return line if the pump is low enough pressure or it uses an internal regulator.
Old December 6th, 2009, 11:25 PM   #5
Yota Bill
the "returnless" systems just return the excess fuel to the inlet side of the pump, essentially, so it doesnt need to return all the way back to the tank, but still does the same basic thing
Old December 6th, 2009, 11:54 PM   #6
jon_xj90
fake it till you make it.
jon_xj90's Avatar
is it a holley red or blue pump? one is internally regulated for carbed setups and intended to run without return, and the other comes with an adjustable regulator. if you have the red it's already set to 7psi, if the blue it'll run up to 14 and is adjustable. either one doesn't require a return though.
i doubt it's the black since that's a high flow, 1.5x the cost, and overkill for your set up.
if it's a different pump, like one intended for an efi setup that has been regulated down to carbed pressure, i'd get a return style regulator on it or a different pump asap.
jon_xj90 is offline   Reply With Quote
Old December 7th, 2009, 10:04 AM   #7
mudviper
getting dirty
mudviper's Avatar
From taking a look at it, it appears to be a Red Holley pump
Old December 7th, 2009, 10:18 AM   #8
AFRd_CJ5
AFRd_CJ5's Avatar
The Holley Red pump does not need a return line or a regulator.
Not sure if you're talking just Holley pumps or what, but some pumps absolutely require a bypass or return setup.
AFRd_CJ5 is offline   Reply With Quote
Old December 7th, 2009, 02:53 PM   #9
jon_xj90
jon_xj90's Avatar
i just assumed it was the red or blue since he specified it was a holley in the first post, and yes some pumps absolutely require a return line.
if it's the red pump it's internally regulated to 7psi and should be fine run the way it is, that's how my chevy is set up and i haven't had a problem in 2 years
Old December 7th, 2009, 05:03 PM   #10
mudviper
getting dirty
mudviper's Avatar
Thanks everyone for your help
Page generated in 0.27516 seconds with 53 queries
