How do you get a broken tap out? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2009, 01:50 PM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default How do you get a broken tap out?
Long story short my roommate broke a tap off in my head
How do we get it out?
Old December 6th, 2009, 02:01 PM   #2
4RDtough
4RDtough's Avatar
Tap extractor. Slides in the flutes of the tap and if your lucky spins it out.
4RDtough is offline   Reply With Quote
Old December 6th, 2009, 02:07 PM   #3
kj kyle
kj kyle's Avatar
grabbit
kj kyle is offline   Reply With Quote
Old December 6th, 2009, 02:25 PM   #4
99RAMMAN
redneckrocko
99RAMMAN's Avatar
had the same problem with an extractor! getting broken plug out of the head chances are your gonna have to pull the head drill it and tap it to be safe
99RAMMAN is offline   Reply With Quote
Old December 6th, 2009, 05:03 PM   #5
Mr. Beefy
BFT!
Mr. Beefy's Avatar
The head is off Killed 2 drill bits in about 35 seconds
Old December 6th, 2009, 05:07 PM   #6
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
I say you cute it out and jb weld it back together...
TechJeeper is offline   Reply With Quote
Old December 6th, 2009, 05:12 PM   #7
Depending on how much of the tap is still in the hole and the size of the tap. I have had luck with simply taking a center punch and breaking the tap apart and getting it out. OR taking two pics and twisting them to spin it out.
Old December 6th, 2009, 05:41 PM   #8
rargreen
88
rargreen's Avatar
x2 & if that doesn't work I go in with a carbide burr and cut it out.
rargreen is offline   Reply With Quote
Old December 6th, 2009, 05:42 PM   #9
jon_xj90
fake it till you make it.
jon_xj90's Avatar
you'll never touch a tap with a standard drill bit, are you on a bench or machine of some sorts?
all the above methods are practical depending on how the tap breaks, and yes there are several ways a tap can break lol
from the sounds of it, you need to get that head in a bridgeport or another machine that's just as rigid. i'm young but i've been a cnc bridgeport and boring mill operator since i was 15 at our family owned machine shop.
i don't even bother trying to extract anymore unless it's a rediculously easy one, you just end up screwing up the part you're working on.
MY ANSWER finally after i digress, is a 4 flute carbide end mill, slow spindle speed, very slow downward feed, and cutting oil. punches a clean hole through every time.
then break out the bits left after you get a hole through it.
jon_xj90 is offline   Reply With Quote
Old December 6th, 2009, 05:49 PM   #10
rubicon
use a tap extraction kit, will cost you about 40 to 50 bucks but will come with drills and pick to remove the tap. depending on what size tap you might be able to use a left handed drill bit and get lucky and get it to back out.
Remember will drilling hard materials low speed on the drill and use lots of lube.
rubicon is offline   Reply With Quote
Old December 6th, 2009, 05:52 PM   #11
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
a die grinder and a punch it can get messy but try to be carefull, i have tried tap extracters and have never had any luck
ATOMIC_BADBOY is offline   Reply With Quote
Old December 6th, 2009, 06:02 PM   #12
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Buy new head. use old one for a nice door stop.
Old December 6th, 2009, 06:04 PM   #13
jon_xj90
jon_xj90's Avatar
btw, what kind of head and what size tap?
Old December 6th, 2009, 06:26 PM   #14
Bc1980
this is easy
philips screwdriver.. close to same size as tap... cut x in the screwdriver...checking for fit often
(may take a couple trys to get it to fit in the 4 holes of the tap)
tap in with hammy atach vice grips to srewdriver and back it out.......
has worked for me everytime i have broken a tap
Bc1980 is offline   Reply With Quote
Old December 6th, 2009, 06:42 PM   #15
Arr-pea
Acceleration Junkie
Arr-pea's Avatar
This has worked for me in the past, make sure to use lots of air or spray lube to clean all the chips dirt and debris out of the hole.
Arr-pea is offline   Reply With Quote
Old December 6th, 2009, 06:57 PM   #16
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Mr. Beefy View Post
How do you get a tap out?
Arm Bar, Triangle choke, rear naked choke, guillotine, etc.
Old December 6th, 2009, 07:05 PM   #17
jon_xj90
jon_xj90's Avatar
hahahaha, nice one
Old December 6th, 2009, 08:06 PM   #18
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I got a new head
Old December 6th, 2009, 08:25 PM   #19
itselliott
itselliott's Avatar
You, Sir, can work in my shop any time!
Problem is, I have a one man shop, but you're absoutely right on
Old December 6th, 2009, 10:00 PM   #20
jon_xj90
jon_xj90's Avatar
thanks itselliot, i do what i can. i've had more broken taps than i can count breaking through plates into tubing sidewalls or gussets. punch them out on my 3B-72 devleig every time.
Page generated in 0.46782 seconds with 83 queries
