1978 CJ7 Build (Pics added 2-5-12) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2009, 09:26 PM   #1
Paperboy326
Paperboy326's Avatar
Default 1978 CJ7 Build (Pics added 2-5-12)
Well my buddy from work says I need a build thread for my project. We Bought a 1979 CJ7 and are working on making it trail ready. Here is some info on the Jeep.
AMC 304 (comp cam, mallory ignition, holley truck avenger carb)
AMC Turbo 400
Superlift Super ride 4" Lift
New Copper STT 35's
Fiberglass Tub, Hood, and Fenders
Here it is on the trailer coming back from Indy where we bought it
Once we got it home, we enjoyed the jeep as is the remainder of the summer.
The whole job started buy installing a soft top and doors the previous owner never had doors of a top for it (only used in summer) and he mounted the seats to far out, so i need to remove the seats and figured since I did that I would pull the carpet out and bedliner the inside. well to do that I need to do some fiberglass work. And to do fiberglass work right you have to glass both side so That meant pulling the tub off. I also wanted to make a nice flat spot in the tub for a center console and the twin sticks. Typical snowball effect with any project.
Once I had the body off I figured it was a good time to fix some spots on the frame, which then turned into fixing the frame, sanding and painting the whole frame as well, pulled the motor, fuel tank, and brake lines, etc.
I got started working on the front and rear bumpers this weekend, here are some pics of the front bumper, not done with it yet need to still get some tube bent to protect the winch, and still need to get my d-ring tabs made and welded on. I painted the frame with Black chassis saver paint.
I have started on the rear bumper and will post pics soon. Will have rear tire swing out carrier, gas can, highlift jack etc. projects still to do are new brake lines, new tie rod ends, weld up a new skid plate for 20 gallon poly tank, raptor u-pol the bottom of the tub and the interior of the tub.
Paperboy326 is offline   Reply With Quote
Old December 5th, 2009, 10:16 PM   #2
nathanthegreat
not really
nathanthegreat's Avatar
looks good. im jealous
nathanthegreat is offline   Reply With Quote
Old December 6th, 2009, 06:39 AM   #3
ckhanna71
ckhanna71's Avatar
Very cool Scott, that guy from your work was right! You need a good build thread with as much work a your doing!
ckhanna71 is offline   Reply With Quote
Old December 6th, 2009, 07:45 AM   #4
deathbypsi
Brian R.
deathbypsi's Avatar
Wow, very impressive. Keep the updates coming!
Old December 6th, 2009, 11:11 AM   #5
drew91xj
drew91xj's Avatar
the integrated roller fairlead is awsome
Old December 6th, 2009, 07:38 PM   #6
Paperboy326
Here are some new pics from the work today. Rear bumper still need to do the d-ring tabs on the front and rear, also did the bottom of the tub in the raptor upol to get a feel for it before I flip it over and do the interior.
Old December 6th, 2009, 09:04 PM   #7
bj house
bj house's Avatar
very nice keep up the good work
Old December 7th, 2009, 09:01 PM   #8
jsmtam90
Old School Jeeper Club
jsmtam90's Avatar
wow...I'm now motovated!...where's the jackstands and my hoist!
jsmtam90 is offline   Reply With Quote
Old December 30th, 2009, 10:02 PM   #9
Paperboy326
Well been busy time to update the pics of my progress. Got the old motor apart, previous owner said it had been recently rebuilt, still had the cross hatching in the cylinders even, so I just put all new gaskets in it and painted it AMC blue, worked on the rear bumper some as well got the tire carrier started and the new 3/16' skid plate for the 20 gallon poly tank, also got the tub flipped over and sprayed the Raptor Upol on the interior.
Thats all for now, I will get some more of the bumpers and the gas tanks skid plate once I get them finished up this weekend.
Old December 30th, 2009, 10:04 PM   #10
89cjwftw
jeeprbrown
89cjwftw's Avatar
89cjwftw is offline   Reply With Quote
Old December 31st, 2009, 12:12 AM   #11
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Send a message via Yahoo to lizzardboy
Great job, keep it up. Cant wait to see more.
lizzardboy is offline   Reply With Quote
Old January 1st, 2010, 07:17 PM   #12
jeepnxj96
jeepnxj96's Avatar
Bumpers look good, can't wait to see them all finished up.
Old January 6th, 2010, 01:56 PM   #13
Paperboy326
Well a special thanks to Ricky (jeepnxj96) for bending up the tube work for me, he really knows his stuff. Here are some updated pics of the front and rear bumpers with the tube work on them
Old January 6th, 2010, 02:21 PM   #14
joe_jeep
welfare wheeler
joe_jeep's Avatar
looks good.
should do the raptor on the outside of the tub too.
Old January 6th, 2010, 09:16 PM   #15
drew91xj
drew91xj's Avatar
how do you like the over all lay out coverage of the raptor stuff we have used it once but never got a chance to see dry final results
Old January 6th, 2010, 09:53 PM   #16
Paperboy326
Love it very even texture and not rough like the roll on stuff. and very easy to spray. the texture is pretty similar to rhino and line-x, but where it falls short of those is the thickness, this is a 1 gallon kit and rhino and linex use somewere in the 5-6 gallon range for truck beds, but then again our interior won't see the same abuse as a truck bed will. I highly recommend the raptor liner looks great, there is a tintable version as well, search jeepforum and you can see some greens and reds people have done.
Old January 13th, 2010, 04:34 PM   #17
jeepnxj96
jeepnxj96's Avatar
No problem Scott, Glad to help, Looks good
Now get it finished LOL
Old January 13th, 2010, 04:42 PM   #18
tweak
Are we there yet?
tweak's Avatar
Very nice build up! Love the attention to detail.
Old January 24th, 2010, 06:27 PM   #19
Paperboy326
had to put the body and motor back in the frame so I could fab up the new roll cage pieces, frame tie ins, new shakles, Big Daddy tie rods w/flip kit, and the rock sliders.
Old January 25th, 2010, 07:39 PM   #20
Paperboy326
got the tire carrier all welded up tonight.
Page generated in 0.38824 seconds with 83 queries
