Reddy heater problem. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2009, 07:41 PM   #1
Fatty Matty
Fatty Matty's Avatar
Default Reddy heater problem.
I just picked up a reddy heater Pro 100 off of CL for $40. It's propane.
I hold the button down for 30 seconds to start it, but when I let go it wont stay lit. I see a spark from the electrode when I let off.
what am I looking for? I'm thinking the thermocouple, but I'm not sure.
'12 JKU
'14 1500
www.midwest-abs.com
Old December 5th, 2009, 07:59 PM   #2
Bc1980
does it go out if you hold it in and quickly turn it to high?
i havent used mine yet this year but i think i have to do something like that with mine or it goes out.
also if your using a little grille propane tank ive found that if it gets to 1/4 of the tank left it wont keep it running.
Bc1980 is offline   Reply With Quote
Old December 5th, 2009, 08:04 PM   #3
Fatty Matty
It goes out the second I let go of the button. It won't let me turn it to high without letting go of the button.
I'm leaning toward it being the thermocouple. I'm going to go tear it apart.
'12 JKU
'14 1500
www.midwest-abs.com
Old December 5th, 2009, 08:06 PM   #4
bj house
bj house's Avatar
try holding down for a little longer but it sounds like the tcouple is bad. I have a reddy and it only takes about 10s of holding it down to keep it lit.
Old December 6th, 2009, 08:05 AM   #5
Immortal
NO RELIGION WAT!
Immortal's Avatar
If not the tcoupler the propane orifice is clogged with a spider web.
Old December 6th, 2009, 08:50 AM   #6
96 s10 blazer
96 s10 blazer's Avatar
try to ruff up the surface of the thermocouple a little and then retry.
96 s10 blazer is offline   Reply With Quote
Old December 6th, 2009, 09:27 AM   #7
tsaguy
Semper Fidelis
tsaguy's Avatar
rape it.
it will learn.
tsaguy is offline   Reply With Quote
Old December 6th, 2009, 09:49 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
Originally Posted by tsaguy View Post
rape it.
it will learn.
too played out.....
2/10
Old December 6th, 2009, 10:38 AM   #9
tsaguy
Semper Fidelis
tsaguy's Avatar
Originally Posted by Immortal View Post
too played out.....
2/10
Consider it a tribute to Fatty Matty rather than a play...
Old January 4th, 2013, 07:44 PM   #10
Fatty Matty
I figured it out, three years later.
It would always work great if the tank was warm, as in not freezing cold. Last winter the hose got cut so I went to the local welding supply/propane joint the other day to get a new one made. I was telling the counter guy about how the thing didn't like to work with a cold tank, he said..."You must be using a 20# tank, they won't work for the bigger heaters, 40# is the minimum".
So....I bought a 40# tank. It works flawlessly at any temp now.
'12 JKU
'14 1500
www.midwest-abs.com
Old January 4th, 2013, 07:49 PM   #11
Immortal
NO RELIGION WAT!
Immortal's Avatar
Here! Now stfu!!
<3,
Immortal
Old January 4th, 2013, 08:32 PM   #12
I suck cocks. Lots of them.
locally famous
Victory
Old January 4th, 2013, 09:14 PM   #13
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Ours states it needs a 100# tank... the heater isn't even that big. Needless to say I have not bought a tank.
Old January 4th, 2013, 09:52 PM   #14
BlooMule
Old School
BlooMule's Avatar
Well, now I know what kind of heater to avoid.
-rw-rw-rw
Page generated in 0.31327 seconds with 64 queries
