f-series/bronco Radiator SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2009, 07:48 PM   #1
Default f-series/bronco Radiator SOLD
Good (used) Radiator from a 96 f250 5.8L Auto non-A/C. Still has shroud attached.
$30 located in Middleville or can bring to Grand Rapids for pick-up.
Interchange comes up with
Ford Truck Bronco 5.0 L 302 CID V8 1985 - 1996
Ford Truck Bronco 5.8 L 351 CID V8 Windsor 1985 - 1996
Ford Truck F150 1/2 Ton - Pickup 5.0 L 302 CID V8 1985 - 1988
Ford Truck F150 1/2 Ton - Pickup 5.8 L 351 CID V8 Windsor 1989 - 1996
Ford Truck F250 3/4 Ton - Pickup 5.0 L 302 CID V8 1985 - 1988
Ford Truck F250 3/4 Ton - Pickup 5.8 L 351 CID V8 Windsor 1989 - 1997
Ford Truck F350 1 Ton - Pickup 5.8 L 351 CID V8 Windsor 1989 - 1997
CheapThrillB2 is offline
Old December 7th, 2009, 03:42 PM   #2
Old December 9th, 2009, 08:00 PM   #3
top
Old December 15th, 2009, 10:35 PM   #4
top
Old December 21st, 2009, 07:39 PM   #5
top
Old December 27th, 2009, 07:34 PM   #6
$25
Old December 31st, 2009, 11:30 AM   #7
nightstalker00
nightstalker00's Avatar
can u get measurements for me???i have a 351w in my bronco 2 and so far i have an auto 4.0 rad...i havent been able to run it yet just concerned that it wont cool it enough...if its close n i can make it work i want it...no leaks???n can u ship it or wait???im in kuwait...
nightstalker00 is offline
Old December 31st, 2009, 11:58 AM   #8
IT would take alot to make this radiator fit in an B2. These radiators are really wide.
Old December 31st, 2009, 11:59 AM   #9
Radiator Core Size : 27 5/8" x 18 3/8" x 2" (2 Row)
Radiator Inlet Connector Size : 1 3/4" Top Right
Radiator Inlet Header Size : 3" x 18 1/2"
or
Radiator Core Size : 27 5/8" x 18 1/2" x 1 1/4" (1 Row)
Radiator Inlet Header Size : 1 7/8" x 18 1/2
I would have to double check which row size it is.
Old January 10th, 2010, 03:37 PM   #10
$20
Old March 14th, 2010, 09:37 PM   #11
top
Old April 18th, 2010, 04:17 PM   #12
Hoofinit
Hoofinit's Avatar
Do you have a flywheel clutch and pressure plate for 351w?
Hoofinit is offline
Old April 18th, 2010, 04:21 PM   #13
nope, it was an auto truck sorry
Old April 26th, 2010, 04:58 PM   #14
top
Old May 4th, 2010, 05:33 PM   #15
top
Old May 5th, 2010, 09:41 PM   #16
Daddy Dan
SBF Nut
Daddy Dan's Avatar
if I can find someone traveling from your area down to me, I'll take it.
Daddy Dan is offline
Old May 5th, 2010, 09:47 PM   #17
I work in Grand Rapids a few miles south of I-96 as well, can bring it there to aid in transfer.
Old May 7th, 2010, 12:05 AM   #18
vontomio
Southern Country Boy !!!
Send a message via AIM to vontomio Send a message via MSN to vontomio Send a message via Yahoo to vontomio
can u ship it cause if so then that would be awesome cause all i really need is just the fan shroud for my 91 ford bronco fullsize ..
vontomio is offline
Old May 9th, 2010, 09:08 PM   #19
Shipping would be a PITA for a $20 part.
Old May 10th, 2010, 04:07 AM   #20
vontomio
how far are you from Adrian, MI ....
vontomio is offline
Page generated in 0.36261 seconds with 83 queries
