Aftermarket Radio Power Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2009, 07:36 PM   #1
awalters
Hired Badass
awalters's Avatar
Default Aftermarket Radio Power Question
I had a Kenwood radio laying around so I swapped it into my TJ. This morning I fired it up, and the radio seemed dead, like it just wouldn't power on. I removed faceplate and blew off the contacts, and put it back in. There is a little red flickering security fake out light on the deck that stays in the dash that flashed. I know there are two power cords, one goes to the ignition wire, and one that goes to the fuse box. Does anyone know why it would just not come on one time? I have not checked the fuses yet, because like I said, the little fake alarm LED still flashed, so I'm sure it HAS power. This has been working fine for about a month now, just one day...
awalters is offline   Reply With Quote
Old December 4th, 2009, 07:51 PM   #2
garemo
I AM BATMAN!!!
garemo's Avatar
Send a message via AIM to garemo
try the constant power wire thats what the issue was with mine it should be a yellow wire it doesn't matter where the power comes from you can run a jumper wire from your main power wire that goes to the radio to your constant also check your ground hope this helps keep in mind i had to install a whole system in my jeep but im pretty sure that is the problem
garemo is offline   Reply With Quote
Old December 4th, 2009, 07:54 PM   #3
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Do you take the faceplate off every time you leave the Jeep, or does it normally stay on?
1988JeepXj is offline   Reply With Quote
Old December 4th, 2009, 07:55 PM   #4
bnmarlatt2004
BigBrutus
bnmarlatt2004's Avatar
definatly check your constant cause if that doesn't have power it wont turn on at all. your constant is what keeps all of your settings and presets in your radio so I wouldn't suggest connecting it to your power but you can do it that way.Just check your wire connections and make sure nothing came loose. hope I helped
bnmarlatt2004 is offline   Reply With Quote
Old December 4th, 2009, 10:06 PM   #5
awalters
Hired Badass
awalters's Avatar
That is what I was thinking. That's what happened in my other car too, but it's weird because I wasn't having any problems with the factory radio, and I used a wiring harness, I didn't jerry rig it to the power source, so it would have to be something on the factory side of things not the aftermarket side.
Ground is a good idea, with the factory radio it was bolted to the back of the radio, with the aftermarket I had to put a few strands of the ground into a butt connector, and crimp that to the radio's ground.
I understand what the constant power does in all, but like I said, when the faceplate is off of the radio, there's a little red flashing LED light that I guess mimmicks an alarm and that light is indeed flashing. If the constant power or ground are broken, I would tend to think that light wouldn't be on at all, but I will check all.
Page generated in 0.22496 seconds with 38 queries
