Harmonic Balancer Removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2005, 12:45 PM   #1
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Default Harmonic Balancer Removal
I got an old 258 (I think, I'm having a little difficult time measuring the stroke while it's in the block). I'm trying to haul the crank and rods out to see if they're still useable, but I can't get the blasted balancer off (without forseeing destroying it, I'd like to have it just in case) and get the timing chain cover off to pull the crank out.
Old November 28th, 2005, 12:50 PM   #2
Medic8
You call, we haul.
Medic8's Avatar
I know this is a really dumb question...
but are you using a proper harmonic balancer puller, or a 3 jaw?
If you're not using the right tool, it can really make things a PITA. Otherwise, try lubing the threads and using an impact gun to turn the bolt in.
Old November 28th, 2005, 04:31 PM   #3
Captain Ledd
Ranger Addiction?
All I have is assorted 3 jaw pullers, which I can see tearing it apart with. Actuallyyyyy, I just now thought of an idea that could work. I have some rod that I can cut up and place under the inner wheel and hook the 3 jaw to them.
if that doesn't work, how would an impact gun drive it off? seems all it would do is crank it on tighter. If I turned it the other way it just unscrews.
Old November 28th, 2005, 04:36 PM   #4
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
save yourself time and trouble. Autozone rents harmonic balancer pullers for free (deposit required)
Old November 28th, 2005, 04:36 PM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
since you torqued on the outer ring. I wouldn't trust it anymore. That is an elastomer ring that allows for it to absrb vibes thru the outer ring. If you have never seen a harmonic balancer fail and the damage it can and will do. I would search it out. Before you decide to reuse the one you just reefed on with the puller.
Now got to an auto parts store and rent a harmonic puller, if not buy one.
Old November 28th, 2005, 04:42 PM   #6
Captain Ledd
Ranger Addiction?
actually I didn't torque on it, I saw that comming first thing. I haven't done anything to it because every idea I had would mess up that outer ring.
for not thinking of autozone.
Thanks guys!
Old November 28th, 2005, 11:48 PM   #7
Medic8
You call, we haul.
Medic8's Avatar
I worded that wrong. That was actually supposed to say something along the lines of "If you ARE using a balancer puller, try using an impact to turn it...".
Disregard my previous statement of stupidity.
Old November 29th, 2005, 05:10 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
impact is your friend unless you rented something different from the pic above.
Old November 29th, 2005, 11:38 AM   #9
Captain Ledd
Ranger Addiction?
HOLY CRAP! We do have one of those in back. I've never used it but I remember seeing it. Awsome, thanks Immortal!
Page generated in 0.21108 seconds with 50 queries
