318 727 q - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2009, 12:18 PM   #1
farm_boy
hicktown
farm_boy's Avatar
Default 318 727 q
ok so i'm doing a biuld with this combo frist off the 727 is not a 4x4 how much work and hassle is it to make that 4x4 i am biulding the engine a litte but what t case bolts to this combo and what count is the output
farm_boy is offline   Reply With Quote
Old December 3rd, 2009, 12:31 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would guess its easier to find a T case & trans that is all together. I have a whole truck for $ 400 that has the trans you need + driveshafts, axles, etc.. the trans needs rebuilt on it or you could drive it home.
M884 army truck for sale...with an update! (11-22-09) - Great Lakes 4x4. The largest offroad forum in the Midwest
Yetti
Old December 4th, 2009, 03:55 PM   #3
269bigoldodge
269bigoldodge's Avatar
In order to change a 2wd tranny into a 4wd tranny you will need a 4wd tailshaft, the adapter housing and transfercase. the factory used a 203 t case in the mid to late 70s. Then they used a 208 and 241 t case you also need to make sure that you get the right t case adapter dodge also used 2 diffeerent t case for the 208, they made them with a bolt on flange and a slip yoke
269bigoldodge is offline   Reply With Quote
Old December 5th, 2009, 10:23 AM   #4
farm_boy
hicktown
farm_boy's Avatar
sop chould i get a kit and put a ford np 208 behind the 727
Old December 5th, 2009, 04:15 PM   #5
269bigoldodge
Dodge trannies have differt splines then ford 208 t cases. Easiest way is to find a 727 with t case still on
Old January 7th, 2010, 08:01 AM   #6
mhicks1017
mhicks1017's Avatar
I have a 727 and transfer case I'll sell for $150. the tranny needs a rebuild though. Is in an 86 3/4 ton.
mhicks1017 is offline   Reply With Quote
Page generated in 0.29993 seconds with 42 queries
