BRAKES keep warping - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2009, 07:46 PM   #1
07mcgeathy
Default BRAKES keep warping
i have a 98 1/2 ton chevy ext cab short box 4x4 all stock with 265, my problem is that the front rotors keep warping every 6000 to 8000 miles. i dont stop hard or pull trailers offten, and have good quality pads and rotors already. any one know what i should do? would it be worth spending alot of money on break parts like drilled and slotted rotors. i do know these trucks are known for this problem, so theres gotta be a solition. thanks for any advice.
07mcgeathy is offline   Reply With Quote
Old December 2nd, 2009, 07:48 PM   #2
special k
special k's Avatar
are the calipers hanging up at all causing the rotors to get hot? all i can think of
Old December 2nd, 2009, 07:58 PM   #3
jeepnxj96
jeepnxj96's Avatar
Are you torquing the lugnuts to 100 ft/lbs ( may be 120 for the trucks, not sure) I know chrysler had a bulletin about rotors warping due to uneven torquing of lugnuts. The alloy wheels would distort and cause uneven pressure on the rotor causing it warp. Also on the Chevy trucks I may actually be your rear drums that are warping or going out of round. My buddy had it happen on his 97. After a couple trips to the dealership and about 3 sets of pads and rotors on the front it was determined the rear drums were the culprit, repaced them and the shoes, problem solved.
I hope this helps
Old December 2nd, 2009, 07:59 PM   #4
Nvrenuf
Nvrenuf's Avatar
I agree there is another problem, I have owned 5 of those trucks and personally put between 100-150k miles on each one and never warped a rotor.
Is one side getting hotter during normal driving?
My Jeep had an issue with the rubber lines swelling that caused the calipers to not release.
Old December 2nd, 2009, 08:00 PM   #5
CrustyChevy
CrustyChevy's Avatar
improperly torqued lug nuts can cause warping problems sometimes
CrustyChevy is offline   Reply With Quote
Old December 2nd, 2009, 08:01 PM   #6
CrustyChevy
oops someone got to it before me :)
Old December 2nd, 2009, 08:02 PM   #7
special k
special k's Avatar
i'll agree with the lugnut torquing also. i know the 97-08 f150's were notorious for warping rotors due to over-torqued lug nuts.
Old December 2nd, 2009, 08:03 PM   #8
jeepnxj96
jeepnxj96's Avatar
It's all good, some people don't read big paragraphs from a possible know it all
Old December 2nd, 2009, 08:06 PM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
How are the rear brakes? I tend to wonder if the caliper slides locked up if they are discs and are forcing the fronts to work harder?
Yetti
Old December 2nd, 2009, 08:09 PM   #10
jeepnxj96
jeepnxj96's Avatar
did they offer rear disc's on 98 silverado's???
Old December 2nd, 2009, 08:09 PM   #11
frdboy
frdboy's Avatar
Make sure the rear brakes are working and adjusted properly, if the fronts are doing all the work it will cause problems.
Old December 2nd, 2009, 08:12 PM   #12
kickstand
circling the drain
kickstand's Avatar
not that I remember
Old December 2nd, 2009, 08:28 PM   #13
07mcgeathy
the calipers are not hanging up already went through that, and the rear breaks are tight i keep them adjusted trying to keep as much stress off the front as i could but that did not seem to help
the rear are drums and i am prett sure they are not out of round
impropper torque on the lugs could be but i havent had any trouble with any of the other cars i have worked on but i will try re torquing them
Old December 2nd, 2009, 08:56 PM   #14
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
driving habits.... My exwife went thru pads and rotors like crazy. She thought she had to stomp on the brakes everytime she stopped and always at the last minute. It played havok on the antilock also.
spr_chicken is offline   Reply With Quote
Old December 3rd, 2009, 03:46 AM   #15
Ebs
Make sure the rear drums are kept properly adjusted, the self-adjusters are known to suck on these trucks.
Old December 3rd, 2009, 05:44 AM   #16
blownexploder94
Todd
blownexploder94's Avatar
does this truck have stock tire size on it? make sure that the front hub where the rotor goes up against is clean, and the rim is clean so there is no debris between them.
Page generated in 0.46999 seconds with 71 queries
