95 cummins 47rh question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2009, 08:46 AM   #1
butters
It curves to the left...
butters's Avatar
Default 95 cummins 47rh question
i have a 95 cummins when cruising at 70-75mph the torque
converter will be locked and then unlock for no reason, then keep
doing the same thing. happens when i'm hardly on the throttle also
when cruise is set. trans and converter are 1 yr. old. if i get into it
a little a and keep my boost up doesn't act up, wondering if anyone
has had this issue.
butters is offline   Reply With Quote
Old December 2nd, 2009, 11:20 AM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Yep, the tps is very sensitive. When the ecm sees no throttle being used, it unlocks the converter. You can do some studying and try to adjust it or read below.
I fixed mine by eliminating the tps like this = http://www.dieseltruckresource.com/d...s-t142641.html
I like the way my tranny works alot better now.
RIP FULLSIZE4LIFE
Old December 2nd, 2009, 01:35 PM   #3
Kegger83cj7
Kegger83cj7's Avatar
There is one other thing that I have heard of. The tranny temp sensor will act up and send a "tranny is hot" signal to the computer. This signal will drop the tranny out of OD to try and pump more fluid thru the cooler. But if your able to remidy this with more throttle then it is most likely the TPS. Just a randum thought. Good luck........
Kegger83cj7 is offline   Reply With Quote
Old December 3rd, 2009, 09:30 AM   #4
butters
butters's Avatar
thanks for the input, installed a tps last nite seems like the converter is
staying locked at light throttle now, did order new throttle linkage because the
ball sockets are worn out.
Old December 3rd, 2009, 11:31 AM   #5
SHARPMACHINE
F-U-CANCER!!!
Were they under re-call? My 94 had a re-call for the throttle linkage.
RIP FULLSIZE4LIFE
Old February 2nd, 2010, 02:06 PM   #6
mudbillyredneck
mudbillyredneck's Avatar
Wow , great link
mudbillyredneck is offline   Reply With Quote
Old February 2nd, 2010, 06:57 PM   #7
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
My 95 has a converter lock up switch in it. Very easy mod and works great. Im sure my tps is not working perfect as it does exactly what you described. With the lock up switch i dont really have to worry about it on the highway.
Old February 11th, 2010, 11:16 PM   #8
Coal Burner
MAKE IT OR BREAK IT
Coal Burner's Avatar
x2 Lock up switch IS THE WAY TO GO!!
Coal Burner is offline   Reply With Quote
Old February 26th, 2010, 02:18 PM   #9
formercruiserhead
formercruiserhead's Avatar
Default torque converter
Do you have larger than stock tires? If they are way over stock, like 35's the gearing is way off and the engine rpm's go way down and the computer can't pick where to keep the trans. Also the tps are extremely sensitive in setting as I used to be a Toyota mechanic and found they are best setting using a volt meter over feeler guages because you can actually see when the signal changes instead of just a gap measurement, also everyone has a different feel with feeler guages that can make a difference on such a delicate adjustment. Just trying to help let us know what you find.
formercruiserhead is offline   Reply With Quote
Page generated in 0.33361 seconds with 50 queries
