T-case/Trans Mount - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2009, 11:12 PM   #1
bacongrease
Am i still a Noob?
bacongrease's Avatar
Default T-case/Trans Mount
ok, need a couple of opinion's
this is a tj, its a dana 300 with 231 planetary case, as it sits i have a crossmember where the original trans mount was.
Do i need another mount for the rear of the 300?
Maybe something the bolts to the rear output?
bacongrease is offline   Reply With Quote
Old December 9th, 2009, 11:39 PM   #2
Suta99
Suta99's Avatar
id say yes
Old December 10th, 2009, 08:59 AM   #3
95geo
newbie
95geo's Avatar
need- not really.... depends on what you plan to do with it. you *should* probably put a rear mount on it to support all that leverage, especially with an aluminum adapter. The polyeurothane chevy trans mounts work good and so do the poly yj leaf spring bushings in a chunk of 1.75x.120 DOM.
Page generated in 0.13226 seconds with 33 queries
