46re Issues need some input - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2009, 05:23 PM   #1
Bc1980
Default 46re Issues need some input
Im pretty sure its smoked..
no / barely moving gears slipping
After removing pan fluid is burnt and seems to be normal dodge schrapnel in pan.
Its throwing a p1763 code
Is it throwing the code because its slipping? or is it that the governor pressure sensor is fd up.
Could all my problems be the governor sensor.
Should i just rebuild it and replace the sensor?
any info apreciated.
Pretty sure im just going to redo it and change the sensor.
Bc1980 is offline   Reply With Quote
Old December 1st, 2009, 08:30 PM   #2
Bc1980
Lack of responses leads me to believe IR Weetarted for working on dodge tranny................
I kind of answered my own ? I guess...
Old December 2nd, 2009, 07:12 AM   #3
Tom
Because racecar
Tom's Avatar
Those are known for bad gov pressure solenoids. If it starts off in the wrong gear, it will feel like a slip/barely move condition. If you have a faulty Gov. solenoid it will default to 3rd gear (or second). If you change the gov solenoid, change the transducer along with it.
Old December 2nd, 2009, 07:22 AM   #4
Bc1980
Thanks, I apreciate all the help I can get this is my first time doing a 46re.
I know most trannies have there common probs though.
Page generated in 0.23655 seconds with 35 queries
