2000 XJ build - "H. Whopperman" - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2010, 12:33 PM   #21
kargod
Charcoal Mellowed
kargod's Avatar
I finally pulled it out of the garage.
I just finished mounting the front bumper bumper I bought used from jeepxj_boy_21 on here. I got the joy of breaking two of the steering gear bolts off in the gear, which I found that no measure of specialty tool or heat could remove. I ended up rethreading them to m12x1.5 and using some fancy VW bolts I had to hold it on. The spacer was also crumbling shit, so it now became 1/2 nuts welded to fender washers. Seems okay for now. The steering shaft pulled out of the mating end and I had to install it exactly 180* off when I put it back (consistent failure). I removed the shaft at both ends to correct this and played hell to force it back inside itself (I wouldn't want to go there either) I finally fixed my screw ups to find that the bumper wouldn't fit with the coolers in front of the front crossmember. The bumper holes had to be relocated, and I will add a tab when the temp goes back above freezing to relocate the third bolt on each side.
freshly seam sealed and re-welded floor.
I want to hurry and get this done, but the winch and axle work will have to wait until tax refund time. I want to get going on this:
kargod is offline   Reply With Quote
Old July 27th, 2010, 09:26 AM   #22
kargod
Charcoal Mellowed
kargod's Avatar
Took it to Rocks and Valleys over the fourth of july weekend. I had charged the a/c in May and have been driving it pretty much every day. It did pretty good.
Brought it back and put in the Aussie I bought from DeMarTools on here and the Rusty's front skid that I got from him as well.
Found that the front skid thing does not like to interface with my drop pitman arm. This will get trimmed when I get it back on a hoist at work. I'm sure something else will break by then.
Old January 7th, 2012, 11:30 PM   #23
kargod
Charcoal Mellowed
kargod's Avatar
Bought new shocks, sliders, and front springs from rubilooe today... time to drag this back out of the backyard and play with it a little more. I'll throw a few pics up when I get stuff together.
Page generated in 0.16817 seconds with 32 queries
