99 cummins engine light - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2009, 10:05 PM   #1
boggin-machine
boggin-machine's Avatar
Default 99 cummins engine light
throw a code p0237
the code days the map sensor has a low voltage.
dealer says theres no part number for map sensor.
code also states that the ecm has detected that intake air pressure below a calibrated value to long.
truck still runs good. still smokes tires through 3rd gear. stilling boosting around 42 pounds.
it also states that it could be a turbo boost sensor. but thats for a ford or gm product. not a cummins product.
Old November 25th, 2009, 10:52 PM   #2
frdboy
frdboy's Avatar
Not sure if it is your problem but there is a MAP sensor, rear of intake.
Old November 25th, 2009, 10:57 PM   #3
boggin-machine
ill go mess with it in a few when the truck cools down.
Old January 14th, 2010, 12:27 PM   #4
DodgeitRamit
DodgeitRamit's Avatar
You are boosting 42 PSI?? What turbo do you have . . . HX35??
I just had a few codes pop up on mine (234, 238) for overboost on my 99, after injector install so I threw a boost fooler on to keep the CEL off and outta limp mode. But anyways . . . are you running an oiled air filter?? Also look on Ebay I saw one the other day for 25 dollars . . . and they give all the part numbers (Mopar and Cummins) too.
DodgeitRamit is offline   Reply With Quote
Old January 14th, 2010, 05:36 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Do you have a programmer? Most plug in at the MAP sensor. 42lbs is over boosting your turbo (if it's stock) by about 7 PSI. It's not doing anything but making hot air and shortening it's live.
JcrOffroad
Zoom Zoom!
Old January 14th, 2010, 06:05 PM   #6
boggin-machine
its not a stock turbo. its a 68 mm turbo
Page generated in 0.23771 seconds with 41 queries
