5.2 oil pump priming - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2009, 09:13 PM   #1
redram98
redram98's Avatar
Default 5.2 oil pump priming
how do i do it? thought it would be a little more straight forward.
redram98 is offline   Reply With Quote
Old November 25th, 2009, 06:48 AM   #2
mopar96
Get Some!!
mopar96's Avatar
You need to take distributor out and make a rod that fits in the slot of the pump like the distributor does. The other end will hook up to a drill electric or cordless whatever you got and spin away.
mopar96 is offline   Reply With Quote
Old November 25th, 2009, 06:01 PM   #3
redram98
redram98's Avatar
na theres a gear inside of the engine which is run by the distributor but not attached to it. im not sure if i pull this gear out how to get it back in w the appropriate timing.
Old November 25th, 2009, 06:07 PM   #4
special k
special k's Avatar
just take the wire off from the distributor to the coil and crank itover.
Old November 26th, 2009, 10:46 PM   #5
redram98
redram98's Avatar
ehh thats kinda hokey.
Old November 27th, 2009, 03:21 AM   #6
snocross2xtremes
snocross2xtremes's Avatar
I looked every where trying to find out how to do this and never found a good way to do it..
snocross2xtremes is online now   Reply With Quote
Old November 27th, 2009, 07:06 AM   #7
jbsjunk
Little Member
jbsjunk's Avatar
I've seen a couple different ways to do this.
1- Take a old oil pump drive shaft and cut the teeth off the drive gear then have a shaft with a slot on it to hook up to your drill.
2- Take the drive shaft out and get a priming shaft that goes direct to the pump from the drill.
OIL PUMP PRIMING SHAFT
Special hardened steel priming shaft fits on any 3/8" or larger drill. Insert shaft into hole where distributor fits. Pressurizes oil galleys to ensure against dry starts and ruining your engine.
P4286800 Oil Pump Priming Shaft (V8) $ 7.95
http://www.jimsautoparts.com/mopar_performance_oiling.htm#oil%20pump%20priming% 20shafts
About 3/4 to the bottom.
Old November 27th, 2009, 02:58 PM   #8
redram98
redram98's Avatar
same here. was hoping i could learn from somebodys elses doing! damn. thanks though. im gonna try to pull that gear out and hope i dont mess up the timing. everything is marked so it shouldnt go too bad as long as i divise a plan to get that drive gear out.
hey thanks for the info jbsjunk but im a step ahead. already tig-ed up my own tools just was not expecting to find this gearset inside the block. every other engine i have done the pump was ran directly off the distributor. guess im still learning the "jeep thing"
Old November 27th, 2009, 09:52 PM   #9
dodgeboy
redneck truck club
dodgeboy's Avatar
ive got the tool to prim mopar oil pumps! just used it on my big block its the same one as small blocks you just have to remember how the gear went when its time to put it back in or put it to TDC. i want to say u can use a peice of 5/16 hex rod like allen wrench but i dont know tomany places to get the rod at.
dodgeboy is offline   Reply With Quote
Old December 2nd, 2009, 03:52 PM   #10
redram98
redram98's Avatar
thanks. i took the gear out and primed it by hand. luckily the p.o had removed part of the firewall to gain access to the distributor. clearance issues like this make me wonder about the engineers designing this crap.
Old December 11th, 2009, 07:16 AM   #11
sonic
sonic's Avatar
Engineers dont have to fix it. They just have to make it so it goes together easy.
sonic is offline   Reply With Quote
Old December 11th, 2009, 03:48 PM   #12
redram98
redram98's Avatar
exactly. most of them have no clue what it is like to work on these vehicles.
Old December 17th, 2009, 12:39 PM   #13
sonic
sonic's Avatar
Its true. Ive worked with engineers and almost done with my bachelors in mechanicle engineering and Have been a mechanic for 10 years. I know all sides! Comes down to just plain ignorant people really.
Page generated in 0.36030 seconds with 62 queries
