fuel gauage on 2001 PU - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2005, 11:31 PM   #1
GerkTJ
GerkTJ's Avatar
Default fuel gauage on 2001 PU
anybody got any idea why my fuel gauge goes to empty and back to full when the truck is sitting still. happens most of the time after a fill up. 2001 Chevy 1500HD.
GerkTJ is offline   Reply With Quote
Old November 5th, 2005, 11:45 PM   #2
Chop
Mischievous Badger
Chop's Avatar
bad ground maybe
Old November 6th, 2005, 09:02 PM   #3
GerkTJ
GerkTJ's Avatar
don't know why it would only do it after filling up if it was the ground?
Old November 6th, 2005, 09:15 PM   #4
clarkstoncracker
lol
clarkstoncracker's Avatar
Ok, now it works fine?
If you are driving down the street, does it go to E until you come to a stop? And then it goes back up to the correct level?
Old November 6th, 2005, 10:35 PM   #5
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
Is this a new problem or has it always happened? its kinda odd, makes me wonder if it is some sort of gauge sweep.
GMCsonoma94 is offline   Reply With Quote
Old November 7th, 2005, 08:26 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
It is a factory defect, I believe it was on silent recall. You may check with the dealer. I have a couple buddies that have the same issuse with their 2000 and newer. They deal with it because you have to replace the pump with the sending unit to fix. It is $$$ even doing it yourself.
Old November 7th, 2005, 09:10 AM   #7
Hodur308
Hodur308's Avatar
Send a message via MSN to Hodur308
Default Same issue
This happened on my 2001 Sierra at about 60,000. I've just learned to live with it and I gauge my fuel load by the miles I drive. I guess I'll just wait until it stops working altogether before I fix it :)
Hodur308 is offline   Reply With Quote
Old November 7th, 2005, 02:53 PM   #8
Da' Blaze
El Presedente HPMSO
Da' Blaze's Avatar
Send a message via AIM to Da' Blaze Send a message via Yahoo to Da' Blaze
Default Fuel Gauge
Very common,Just like the fuel pumps going bad, the gause does also, usually one before the other of course. A new fuel pump comes with a new gauge rehostat, which also can be bought seperately, but you still have to drop the tank and put it in (whatabitch). To permanently fix this problem, change the stat on the pump, not difficult after you drop the tank, then grab a
Da' Blaze is offline   Reply With Quote
Old November 7th, 2005, 03:21 PM   #9
GerkTJ
GerkTJ's Avatar
thanks, I'll check at the dealership and see what they say!
Old November 7th, 2005, 09:32 PM   #10
scottie
Eye candy
scottie's Avatar
Drop the tank, I think the prefered Method on S trucks is to remove the bed, I am sure i will find out soon,
Old November 7th, 2005, 11:28 PM   #11
Da' Blaze
El Presedente HPMSO
Da' Blaze's Avatar
you can definately take the bed off, easier if you have a lift though and air power. Aligning the bed with no lift is a biatch. Actually, doing any kind of repair without a lift is a biatch. If you do have a lift, take the bed off definately :D
Old November 8th, 2005, 01:46 AM   #12
GMCsonoma94
1 wheel peel
pfff lift? just need 4 of your friends and some to keep them happy, then all your problems will go away
Old November 9th, 2005, 03:04 AM   #13
Mclovin
"The Situation"
Mclovin's Avatar
if its a short bed you really only need like 2 maybe 3 to keep it steady..
Old November 19th, 2005, 03:34 PM   #14
AWK
AWK's Avatar
I'll look into this for you on Monday. The one post about the pump is valid, but it's the card that is the concern, not the pump. The card has been released as a separate part and is now made of a precious metal to reduce corrosion caused by the sulfur in the fuel.
AWK
AWK is offline   Reply With Quote
Page generated in 0.36447 seconds with 65 queries
