AX-15 core 93 up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2009, 05:21 PM   #1
Tom
Because racecar
Tom's Avatar
Default AX-15 core 93 up
I need a decent core. By decent I mean everything in the first gear area in good condition everything else can be grenaded. Cheaper the better. It MUST be from a 93 and up. Let me know what you have.
Thanks.
*edit: oops it needs to be a 93 and up.....
Old November 24th, 2009, 05:35 PM   #2
Bleay
sick of jackstand wheelin
Bleay's Avatar
I know where you can get a nv3550 to swap in instead.
Bleay is offline   Reply With Quote
Old November 24th, 2009, 06:02 PM   #3
fabricator
throttle jockey
fabricator's Avatar
93 yj 4.0 motor parts and 231 case - Great Lakes 4x4. The largest offroad forum in the Midwest
fabricator is offline   Reply With Quote
Old November 25th, 2009, 10:47 AM   #4
mrtransam78
im getting ready to part out a 92 with an AX 15. It works fine but 4th and 5th gear are noisy
mrtransam78 is offline   Reply With Quote
Old November 26th, 2009, 09:09 AM   #5
capone
capone's Avatar
ttt
capone is offline   Reply With Quote
Old November 26th, 2009, 10:10 AM   #6
mtheaded
what parts are you looking for? i have a disassembled ax15 sitting here that i've robbed a few parts off...
mtheaded is offline   Reply With Quote
Old November 30th, 2009, 08:24 AM   #7
Tom
Because racecar
Tom's Avatar
What year trans?
First gear, first/second gear slider & hub, 1-2 shift fork & rail, detent springs & detent balls.
Old November 30th, 2009, 11:10 AM   #8
mtheaded
not sure of the year, but i assume the only difference is the tooth count?
Old November 30th, 2009, 11:21 AM   #9
Tom
Because racecar
Tom's Avatar
no, brass engagement area/ thickness.
Page generated in 0.21970 seconds with 51 queries
