NGK Powerdex AFX Wideband Air Fuel Monitor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2009, 03:51 PM   #1
79Cherokee
79Cherokee's Avatar
Default NGK Powerdex AFX Wideband Air Fuel Monitor
Used for two summers. $160 includes meter, harness, used Bosch sensor and weld in fitting.
Manual is here;
http://www.ngksparkplugs.com/pdf/AFX...ual_REV_06.pdf
http://www.ngk.com/afx/
Option2:
Option 2 AFX w/Bosch sensor and a new NGK that was on back order so long, it arrived after removing the meter from my car.
http://www.bmotorsports.com/shop/pro...roducts_id/580
$410
Located in Grand Blanc, MI
79Cherokee is offline   Reply With Quote
Old July 2nd, 2010, 04:50 PM   #2
79Cherokee
79Cherokee's Avatar
ttt
Old April 1st, 2012, 07:14 PM   #3
79Cherokee
79Cherokee's Avatar
ttt
Old April 1st, 2012, 11:26 PM   #4
gravedigger1
gravedigger1's Avatar
Default afr
take $125 and will i need to buy a new bung and probe? let me know you can txt me at 616-836-5856 thanks brian
gravedigger1 is offline   Reply With Quote
Old April 2nd, 2012, 04:34 AM   #5
79Cherokee
79Cherokee's Avatar
Sensor worked when removed, new bung included. I updated the post with another option for those worried about the sensor.
Page generated in 0.20568 seconds with 38 queries
