Deranged 3.0 - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2011, 01:42 AM   #101
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
Originally Posted by Mr. Beefy View Post
Nothing wrong with that.
Think of it this way:
IF I cut it off now I'll find money to put it back on.
Funny that u chimed in cause ur truck makes me do the same thing then I remember that its a dodge just kidding beefy I really liked the way urs came out
s10v8zach is offline   Reply With Quote
Old April 28th, 2011, 02:08 AM   #102
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by Fraser View Post
Sweet you got that sig off pirate didn't you
Yup!! Saw that last night, after I quit crying from laughter and climbed up off the floor I had to share it in my sig.
Originally Posted by s10v8zach View Post
ive been wating for u to start up on this thing agian. every time i look at this thing i pick up my sawzall and head towards my truck with a evil grin then i remember i dont have a tubing bender or money for tubing o well someday i guess
Sorry it took me so long to give you any new ideas I have had a few "life moments" get in the way in the last few months. This truck was 75 miles from me from Sept '10 to March '11 due to my wife and I moving to a different house and not having room for it. Then my work schedule also doesn't allow for much if ANY free time lately.
But enough whining and excuses from me, I will working on it every chance I get from now until I finish this segment of the build. I should have new progress to report weekly moving forward.
In about 2 hours I will be making the trip north to rescue my 42's
Old May 30th, 2011, 11:22 PM   #103
bigblockford79
Big Block Ranger
Default Some Progress
Been slowly picking away at things lately.
- Switched back to SRW front hubs and got back to 84" wide
- Cut off old Front axle link mounts and mad new offset on 15*
- Bent front link tubes 15* to gain some steering after sucking the tires back in
- Front axle is done except for brakes and lube
- Built the spare tire mount
- installed and cut hood
PICS
Bent ram from bending 2" 1/4 wall DOM
Front Link mount rebuild
Spare Mount
Hood (still needs some smoothing out)
42's on
Old June 3rd, 2011, 06:47 PM   #104
bigblockford79
Big Block Ranger
Got the new front brake setup installed this morning. My factory set-up was old and sloppy and I felt unsafe, so I purchase conversion brackets to switch over to cheby 3/4 parts. For the most part everything was bolt on, I did have to grind a couple spots a little to provide better clearance but not much. The biggest issue was not having any instructions to clarify with bracket was left or right and where the thin shim went (could go next to the knuckle or spindle). I ended up having to try all 4 combos before getting the right setup.
Old June 4th, 2011, 03:15 AM   #105
creeping death
I'm that guy.
creeping death's Avatar
about time you did something.
i like what you did with the links and the spare carrier turned out schweet.
i see your spare is grooved, you going to groove the other four tires? i have a knife.
Old June 4th, 2011, 03:19 AM   #106
bigblockford79
Big Block Ranger
Thanks. The spare tire carrier just kinda happened that way and I am very happy with the result.
I probably won't groove them any time soon. But when I do, you can bring your knife and I will get mine and we can burn some rubber together.
Old July 11th, 2011, 01:13 AM   #107
bigblockford79
Big Block Ranger
Got quite a bit closer to completion this weekend - Brakes, steering, cooling, transmission cooler, and tranny-tcase shifters are done. Just need to finish dash, wiring, some minor plumbing and securing hose/lines, and a rear drive shaft. Then its time to roll it out one last time and put the shocks on it and start beating the hell out of it.
OH and it also RUNS!!!!!!!!!!!!!!!!!!(Sound quality is a little bad due to the open header 460 being a bit noisy)
Old July 11th, 2011, 04:36 AM   #108
boggin-machine
boggin-machine's Avatar
its alive finally! bet you cannt wait to drive it now huh!
Old July 11th, 2011, 11:25 AM   #109
creeping death
I'm that guy.
so...... when we going for a ride?
Old July 11th, 2011, 08:40 PM   #110
bigblockford79
Big Block Ranger
Hold yer horses buck-o....You'll get a ride soon enough
I still have a few more hours of work until it's ready for some test & tune, but it looks good for it to make it out in 2 weeks. The list keeps getting shorter (as long as I keep forgetting to remember everything that still needs to get done..haha), so the end of this phase of the build is in sight.
I "drove" it a little this morning, if 1' forward and back a couple times constitutes driving. See proof of movement below.
Old July 12th, 2011, 02:52 PM   #111
pos
sweet! now you need that pos f-350 out of your way haha
pos is offline   Reply With Quote
Old July 12th, 2011, 07:59 PM   #112
bigblockford79
Big Block Ranger
Why would I want to get rid of my house's hood ornament??? I think it has grown roots.
Old July 13th, 2011, 11:16 PM   #113
Windsorf350
Rusty Racing
Windsorf350's Avatar
i think it likes being there because nothing ever works to help me get it out of there... but looks like the ranger/ whatever it is... is turning out well whats the plan for exhaust and fenders
Windsorf350 is offline   Reply With Quote
Old July 14th, 2011, 01:29 AM   #114
bigblockford79
Big Block Ranger
Exhaust will be very simple, 3" off the collectors into a chambered muffler, another short section of straight pipe and a turn down. Having fender exit headers really simplifies things.
Fenders...hmm...at this point I have no idea what to do for fenders. I am leaning towards "skinning" the tubing with some light gauge steel and calling it good. I would like to use modified factory fenders, but I think by the time I cut them and make them fit there won't be much left of them. So for now it stays like it is, I won't run a lot of wet stuff and will be careful when I don't have a choice. I really just need inner fenders to keep the engine from getting crap thrown onto it.
Old July 14th, 2011, 10:04 AM   #115
disturbedsledneck
disturbedsledneck's Avatar
Sweet build & some good progress
disturbedsledneck is offline   Reply With Quote
Old July 14th, 2011, 11:57 AM   #116
bigblockford79
Big Block Ranger
Talking
Thanks, I am down to the wire now. I need it done by next Friday, I really need to run it instead of staring at it all dusty and incomplete. It needs some fresh dirt on it.
On a side note I already have a small issue - I had a friend over a bit ago to check the truck out and decided to drive it out of the cave turn it around in the yard and drive it back into the garage. Simple enough right? Not quite, I get out in the yard a ways and start making my turn and all he sudden I am no longer moving and something is grinding pretty bad. My first thought was the pump in the tranny was bad again, but I still have great pressure only gauge. I mess with the t-case shifters and it stars to move again and isn't grinding, which is strange because the grinding seemed to be more towards the front of he truck not right under neath me. Another few feet ant it isn't moving again and the noise is back WTF!! Just as I jump out to see what the he'll is going on my buddy tells me the front shaft is spinning but I am not moving, which doesn't make sense because both hubs are locked in, I looked at the drivers hub and notice it has unlocked on it's own, great. I lock it back in and figure that I must have forgotten to engage the passenger side hub. The noise is gone and I am back moving again so I pull it back in the garage and shut it off. I then look to see if I ever engaged the right side lockout, imagine my surprise when it is still fully engaged. FML
Moral of the story: My brand new milemarker SS hubs are broken. They have about 200 feet on them in a wide sweeping turn at idle on 28" rollers in grass on flat ground. Sucks but shouldn't be hard to get them warranteed since they guy that was at my house is the manager at the store I bought the hubs at.
Old July 14th, 2011, 11:59 AM   #117
bigblockford79
Big Block Ranger
Talking
On a side note I already have a small issue - I had a friend over a bit ago to check the truck out and decided to drive it out of the cave turn it around in the yard and drive it back into the garage. Simple enough right? Not quite, I get out in the yard a ways and start making my turn and all he sudden I am no longer moving and something is grinding pretty bad. My first thought was the pump in the tranny was bad again, but I still have great pressure only gauge. I mess with the t-case shifters and it starts to move again and isn't grinding, which is strange because the grinding seemed to be more towards the front of he truck not right under neath me. Another few feet ant it isn't moving again and the noise is back WTF!! Just as I jump out to see what the he'll is going on my buddy tells me the front shaft is spinning but I am not moving, which doesn't make sense because both hubs are locked in, I looked at the drivers hub and notice it has unlocked on it's own, great. I lock it back in and figure that I must have forgotten to engage the passenger side hub. The noise is gone and I am back moving again so I pull it back in the garage and shut it off. I then look to see if I ever engaged the right side lockout, imagine my surprise when it is still fully engaged. FML
Old July 14th, 2011, 01:16 PM   #118
creeping death
I'm that guy.
well, good thing it was only a lockout.
and that you have a guy on the inside.
Old July 14th, 2011, 04:33 PM   #119
Windsorf350
Rusty Racing
hey brandon i know my truck isnt going anywhere quick if you need to take my lockouts off you can have them ill get some more stockers to replace them...
Old July 22nd, 2011, 07:19 PM   #120
bigblockford79
Big Block Ranger
It is finally near completion, aside from some cosmetic items it is basically done for this phase. The 460 really likes the propane over the carb setup, it has much better throttle response and seems to make more power (mostly due to better atomization and fuel/air mix). I have one issue that will need to be fixed in the future - In the video you will see a lot of white smoke after getting on the brakes hard, this is from the hydro boost dumping too much fluid back in to the reservoir at once and blowing power steering fluid past the cap. I will need to switch to a resi with a better cap that will withstand the flow/pressure of heavy braking.
(video quality isn't the best but you'll get the idea)
http://s627.photobucket.com/albums/t...t=P7220297.mp4
http://s627.photobucket.com/albums/t...t=P7220298.mp4
Page generated in 0.43742 seconds with 85 queries
