Deranged 3.0 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2010, 10:09 PM   #21
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by TBSdontstop View Post
Looks good cant wait to see it run!
Me either. It needs to warm up outside though. It is very hard to get a lot done when you are freezing you azz off.
Old January 10th, 2010, 11:06 PM   #22
TBSdontstop
TBSdontstop's Avatar
Yeah I know what you mean I have to do some work on my moms truck so I can get the garage but its so cold it makes it hard to want to go out.
TBSdontstop is offline   Reply With Quote
Old February 12th, 2010, 09:01 PM   #23
creeping death
I'm that guy.
creeping death's Avatar
looks good, brandon!!!
keep the pix coming!
Old February 12th, 2010, 09:08 PM   #24
bigblockford79
Big Block Ranger
Thanks, I have some new pics I need to get up here.
I ended up calling Ballistic to check on my order after I got off the phone with you. Most of my order will be at my house middle of next week.
Just got the new summit radiator, Derale dual fans, fan thermostats, and a brake distribution/adjustable proportioning valve.
Now I just need to get motivated to get the cage done and can start installing these new beauty's. Not sure what it is but new bling helps motivate me to work out in the cold.
Old March 3rd, 2010, 03:24 PM   #25
bigblockford79
Big Block Ranger
The big brown truck has been visiting quite a bit lately :)
Gears and Lockers:
Dana 60 vs. 80 Detroit locker. (The Dana 80 is on the Left)
Radiator and Fan Set-up
New LED signal lights
New Cab floor covering
Old March 6th, 2010, 02:36 PM   #26
bigblockford79
Big Block Ranger
Got some new parts made today with the help of jeepnxj96. Thanks a lot!!!!
Tube adapters
Roll cage Tube Clamps
Old March 6th, 2010, 08:27 PM   #27
jeepnxj96
jeepnxj96's Avatar
Those are some sexy parts.........except for that big Ford Racing mat
J/K...my heep will have a Ford rear axle
Old March 11th, 2010, 11:13 PM   #28
somer1
You Get the Big One
somer1's Avatar
Where did you get your radiator and fan set up from?
somer1 is offline   Reply With Quote
Old March 11th, 2010, 11:15 PM   #29
bigblockford79
Big Block Ranger
I got them from Summit Racing. The rad is Summit brand and the fan setup is Derale. I can get you Part numbers if you like.
Old March 11th, 2010, 11:19 PM   #30
somer1
You Get the Big One
somer1's Avatar
I would like the # for the fan shroud and also do know what size it is ? Both the radiator and the shroud?
Old March 11th, 2010, 11:36 PM   #31
bigblockford79
Big Block Ranger
Dual fans - 26" Wide by 18 high - http://www.summitracing.com/parts/DER-16927/
Radiator - This one is 30.875" Overall Width and the core is 27.25x18.00x2.25 with 1" diameter tubes. They also have Chevy style versions as well.http://www.summitracing.com/parts/SUM-380431/
Fan Thermostats - http://www.summitracing.com/parts/DER-16759/
Old March 12th, 2010, 12:17 AM   #32
somer1
You Get the Big One
somer1's Avatar
Thank you very much.
Old March 12th, 2010, 12:19 AM   #33
bigblockford79
Big Block Ranger
You are welcome, I used one of these radiators on my truck last year when it had the 302 in it and they work great. As long as the core was clean i never had temp. issues. On top of that the quality is very good, not sure what would make a more expensive radiator better since these from Summit are more than adequate.
Old March 12th, 2010, 02:24 AM   #34
insane88yj
insane88yj's Avatar
Man lookin sweet. I need to start a build on here of my trail rig I"M building. Since I got it back from JCR. Have to figure out how to post pics first.
BTW the boggers should look nice on it. LOL
insane88yj is offline   Reply With Quote
Old March 12th, 2010, 02:30 AM   #35
bigblockford79
Big Block Ranger
Did you get the axles and tires from Mark Yet?
Old March 12th, 2010, 03:01 AM   #36
insane88yj
insane88yj's Avatar
No I am waiting still. If he doesn't have them out in next week or 2 I am gona start houndin him cause I will have the YJ back from paint ready to start assembly. Or just go over with jack & blocks and help my self. LOL
Old March 12th, 2010, 05:23 PM   #37
Looks good Brandon, keep it up
Did Ricky make the roll cage tube clamps?
Old March 12th, 2010, 05:33 PM   #38
bigblockford79
Big Block Ranger
Yes, Ricky cut them for me. Did a damn fine job too!!
Old March 15th, 2010, 09:33 PM   #39
jeepnxj96
jeepnxj96's Avatar
Gonna look sharp Brandon, if you have the mat'l I would consider some scrub bars to run along the cab for when we go to Drummond in Aug.
Old April 13th, 2010, 11:43 PM   #40
bigblockford79
Big Block Ranger
Default Update
After measuring and mocking up the front 3 link and steering I had some major clearance issues with the stock front cross member in the frame. I also was stuck as to how I would box in the front of the frame to add strength to allow me to attach my engine roll cage and shock hoops.
Here is the answer:
The tube is 4x5" 3/16"wall and the plates are 1/4. This will give me plenty of clearance for the front diff and also be a good platform for building tube work off of.
Page generated in 0.69037 seconds with 84 queries
