Deranged 3.0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2009, 12:16 AM   #1
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Default Deranged 3.0
I am once again re-building my truck. I had a pretty good combo last year that performed quite well. It did however have its weaknesses and areas that needed improvement. Instead of just fixing the few things I decided to start from ground zero again and use my 79 F-250 frame and power train as a platform instead of the weak ranger frame. I will be moving to 42" TSL's on H1's, Dana 60 Front w/ 5:13 and detroit locker, Dana 80 rear w/ 5:13 and detroit, 460 CI BBF, built C6 manual, and np205.
I am hoping to have this done by April/May 2010.
These are some pics of the start of the project which meant a complete dis-assembly of the truck and scrapping out the unneeded parts.
ID:	53119   Click image for larger version
ID:	53120   Click image for larger version
ID:	53121   Click image for larger version
ID:	53122   Click image for larger version
ID:	53124   Click image for larger version
ID:	53125   Click image for larger version
Old November 24th, 2009, 12:18 AM   #2
bigblockford79
Big Block Ranger
Default Brake System Upgrades
Pics of rear disc set-up and hydro-boost.
ID:	53127   Click image for larger version
ID:	53128   Click image for larger version
ID:	53129   Click image for larger version
ID:	53130   Click image for larger version
Old November 24th, 2009, 12:21 AM   #3
bigblockford79
Big Block Ranger
Default New Tires/Wheels/Axles/Powertrain
Various Pics of other new components.
New heater box is a non-A/C version off old B2 at LKQ to make some room on the firewall to fit the BBF.
ID:	53131   Click image for larger version
ID:	53132   Click image for larger version
ID:	53133   Click image for larger version
ID:	53134   Click image for larger version
Old December 16th, 2009, 03:36 AM   #4
bigblockford79
Big Block Ranger
Default Tires and Axles Under Truck
Finally forced myself to stay up late and put the new axles under the truck.
Front is a HP Dana 60 with dually hubs and high steer, rear is a dana 80 dually converted to disc.
I know my u-bolts are too long, I won't be using them anyway.
As it sits it is too long and too tall in my book. It is a 126" WB after shortening it once from 132". I think I want to push the both axles forward and chop the back of the frame and end up around 116"-120" WB. The height is way too tall since the rear frame rails come to my chest and I am 6'2". I will adjust the height after the cab gets installed and I have the coilovers ready for mockup.
Old December 16th, 2009, 10:47 AM   #5
86scottsdalek10
86scottsdalek10's Avatar
nice project.......once again i see another ranger and it makes me jealous, although this one is a hardcore 4x4. cant wait to see more
86scottsdalek10 is offline   Reply With Quote
Old December 16th, 2009, 11:37 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
why the Dually axles ?? just wanted a ton of width or what ?
Old December 17th, 2009, 12:18 AM   #7
bigblockford79
Big Block Ranger
Thanks, I am finally getting to build the truck I have wanted since high school.
I am stuck at work a lot lately so it may be a while yet before I get much more done.
The only Dana 80 that I could find was a dually so that is why I started with a dually rear. Then I bought some H1 wheels that wouldn't clear my steering arms. I had 2 choices, re-center the wheels, or run dually hubs up front and a small spacer on the rear. I haven't measured the overall width outside the tires yet but it should only be a little wider that a SRW set-up with the wheel offsets.
Old December 17th, 2009, 12:31 AM   #8
Mclovin
"The Situation"
Mclovin's Avatar
Ahh H1s ok i missed that part..
Old December 18th, 2009, 09:32 AM   #9
VonDirt
VonDirt's Avatar
looks like its gonna be nice
what kind of ride height (frame to ground) are you shooting for ?
since chest high is no good
VonDirt is offline   Reply With Quote
Old December 19th, 2009, 12:15 AM   #10
bigblockford79
Big Block Ranger
Thanks, I keep changing my mind on the end result. I think I am leaning towards a truggy style build instead of a full truck. The reason for this is directly related to the other question you asked, I want the ride height as low as possible but still be able to clear the 42's at full stuff with 14" coilovers. I don't think I could be much lower than what it is right now if I keep the true truck form. At least with the truggy I can get the front and rear fenders out of the way.
I should be able to get away with about a 26-30" ride height. The ride height on the ranger last summer was 26" and I had plenty of room with the suspension I had then and 39" boggers. I know I will need a little more room with the new tires and a suspension that will actually flex.
Old December 31st, 2009, 10:40 PM   #11
bigblockford79
Big Block Ranger
Cab is now mounted
Cut the back section of frame off:
Welded on the new rear frame cap which will also be my mounting plate for the tube back-half.
The "wings" that extend out past the rails on the cap plate will be bent around and welded to the side of the frame rails for extra strength. I will also be boxing the frame and adding some extra inside gussets to make sure everything stays put.
Old December 31st, 2009, 10:46 PM   #12
insaneoffroader
insaneoffroader's Avatar
What your not going to run the super flexy AB springs in the back? hahaha
insaneoffroader is offline   Reply With Quote
Old December 31st, 2009, 10:57 PM   #13
bigblockford79
Big Block Ranger
Definitely NOT I don't know if enough fat chicks would fit in the bed of a truck to make those damn springs even move. The fronts don't move at all when I set the weight of the frame, a 460, c6, and np205 (which is about 1300lbs) on them. AB Spring says they are correct for the truck I just need more weight. HAHAHA I should put pics of the shackle and how it is pulled so far forward that it hits the frame. I decided I was done f-ing with them to make the springs right and will be running coil-overs.
Old December 31st, 2009, 11:01 PM   #14
insaneoffroader
ya i've run the AB springs before. never again!
Old January 7th, 2010, 11:32 PM   #15
bigblockford79
Big Block Ranger
Got the rear frame plate bent around the outside of the frame and welded.
Started boxing the frame, have one side done. Most likely will get to the other side this weekend.
I also cut what was left of the inner fender supports off of the cab.
I hope to have the frame finished by sat. morning and re-mount the cab. Then I will take final measurements for the back-half and draw it up in Bend-tech. If everything goes well and I have the right amount of ambition I make be bending tube on Sunday.
I have also decided that I will be moving the frt axle 8-10" forward, this will put the tires about 2" forward of the stock frame horns. I wasn't going to move the front axle due to steering box relocation issues. The stock F250 box already need to be moved ahead 2-3" to line up the the highsteer arm. Which meant that moving the axle forward 8" would have made it necessary to notch out my bumper to clear the gear. This would not look good at all.
Then I remembered that I have a 77 F-150 gear, this box was meant for crossover steering and mounts to the outside of the frame instead of the inside. I also puts the pitman arm out towards the front of the truck instead of towards the rear like the 250 gear. This will allow me to mount the F150 gear in the stock location and line-up perfectly with the steering arm after the axle gets moved forward.
Old January 8th, 2010, 12:09 AM   #16
koochman450r
koochman450r's Avatar
so are you just linking the back? Looking good I'm getting some ideas for my ranger.
Old January 8th, 2010, 02:03 AM   #17
bigblockford79
Big Block Ranger
It will be Triangulated 4-link front and rear with 14" coil-overs. It will be a truggy with a cage that runs from the front to the back.
Old January 8th, 2010, 09:25 AM   #18
Ford forever
Bought another jeep
sweet build.... makes me wish i still had my ranger
Ford forever is offline   Reply With Quote
Old January 9th, 2010, 08:16 PM   #19
jeepnxj96
jeepnxj96's Avatar
Looks good
Old January 10th, 2010, 08:58 PM   #20
TBSdontstop
TBSdontstop's Avatar
Looks good cant wait to see it run!
TBSdontstop is offline   Reply With Quote
Page generated in 0.64656 seconds with 84 queries
