65 inch drive shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2009, 10:42 PM   #1
warner
oops, shit happens.....
warner's Avatar
Default 65 inch drive shaft
I'm looking for a drive shaft that is 65 inches from center of u joint to center of u joint, non slip shaft
warner is offline   Reply With Quote
Old November 22nd, 2009, 10:59 PM   #2
special k
special k's Avatar
i got an axle for you lol
Old November 23rd, 2009, 05:36 AM   #3
warner
warner's Avatar
bump
Old November 24th, 2009, 12:59 AM   #4
warner
warner's Avatar
ttt
Old November 24th, 2009, 08:52 AM   #5
Zebrafive
By non slip shaft, do you mean no slip joint in the shaft or the trans end can not be the slip in type?
Zebrafive is offline   Reply With Quote
Old November 25th, 2009, 08:26 AM   #6
Zebrafive
If you do NOT want a slip yoke that goes into an auto, but U-Joints each end, Ford F250 rear drive shaft may work. LMK and I'll measure it. $50 picked up.
Old November 27th, 2009, 08:35 AM   #7
mudbillyredneck
mudbillyredneck's Avatar
I have several 3 & 4" diam aluminum ones , with the floating slip yoke to go into the trans....the shaft itself is solid = $50 with good 1330 &1350 ujoints in them already
mudbillyredneck is offline   Reply With Quote
Page generated in 0.16004 seconds with 44 queries
