chevy 4.3 bogging - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2009, 08:11 PM   #1
BlueBlazer98
Winning
BlueBlazer98's Avatar
Default chevy 4.3 bogging
i have a 98 s-10 blazer, and resently when i put it to the floor from a dead stop it will bog for a second, then it will accelerate normally after that. if i acclerate normally it wont do it, only when i punch it. i have no idea what it could be. my therostat is stuck open, so thats broken, but i wouldnt think that thats the problem
im going to change the thermostat this week, but i dont think that will change anything. any help or suggestions of what it could be would be helpful. Thanks!
BlueBlazer98 is offline   Reply With Quote
Old November 23rd, 2009, 07:29 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
replace the fuel filter
hamsmotorsports is offline   Reply With Quote
Old November 23rd, 2009, 08:01 PM   #3
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Might just be time for a good old fashion tune-up. Plugs, wires, air filter, fuel filter, throttle body cleaning...
BAD93SBLZR is offline   Reply With Quote
Old November 23rd, 2009, 09:05 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
maybe your truck is telling you not to drive it like a race car?
Old November 23rd, 2009, 09:38 PM   #5
Disturban
Disturban's Avatar
Ditto...plus cap, rotor and clean MAF sensor! DO NOT clean MAF sensor with carb cleaner, brake cleaner ect...Use CRC MAF Sensor Cleaner!!!
Old November 24th, 2009, 01:12 AM   #6
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Clogged cat?
Grunto is offline   Reply With Quote
Old November 24th, 2009, 10:59 AM   #7
BlueBlazer98
Winning
its all good to plugs and wire. i replaced them late last winter cause i blew up the motor,and its not the cat either cause i dont have one.ha but also it doesnt do it when im in neutral and put it to the floor, its only when im in gear.
Old November 25th, 2009, 11:51 PM   #8
BlueBlazer98
Winning
bump
Old November 26th, 2009, 06:08 AM   #9
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
my 99 jimmy dose it too because of the fuel filter when it get's pluged
beaterk5 is offline   Reply With Quote
Old November 26th, 2009, 11:07 AM   #10
BlueBlazer98
Winning
ill change the fuel filter and see if it changes. thanks
Old November 26th, 2009, 02:02 PM   #11
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
If it don't change when you change the fuel filter, check the fuel pressure. It can still run if the fuel pressure is a little low. The spec is 60-66psi. If its lower than that and you have a new filter make sure there are no other restrictions in the lines, and if there are none replace the fuel pump
Page generated in 0.17091 seconds with 56 queries
