2002 b150 van 3.9L engine issues? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2009, 05:07 PM   #1
joe_jeep
welfare wheeler
joe_jeep's Avatar
Default 2002 b150 van 3.9L engine issues?
my friend just picked up a 2002 dodge b150 van. its real a clean plain jane work van. the 3.9L in it was overheated badly. the radiator is shot. it turns over very well. has almost no compression on one or two cylinders. we were guessing at cracked heads, but have not torn it down yet to see. anything we should look into?? any problem areas common for the 3.9L?? we have never messed with a 3.9L and was hoping someone had dealt with this engine in depth and could point us in the right direction. he got it super cheap and is willing to rebuild the engine completly if necessary.
any advice is appreicated!
the 3.9L is a 318 minus 2 pistons correct??
thx
Old November 22nd, 2009, 07:24 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
the 3.9 is the same as a 318 is the one or two cylinder companion cylinders if so may just need a head gasket, have dealt with a few of these with the same issue dont remember having to replace a head let me know if ya got any questions give me a call yo got my # chuck
hamsmotorsports is offline   Reply With Quote
Old November 22nd, 2009, 08:02 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
all of the magnum engines 3.9 5.2 and 5.9 have cracked head problems at one point or another. if 2 cylinders next to each other are dead then it might have a blown head gasket between cylinders, otherwise it might have a cracked head.
Old November 23rd, 2009, 08:08 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
we messed with it tonight. it will turn over with a socket on the crank just barely now. the starter would not turn it over anymore. when we first went to look at it it did turn over. we took the plugs out they all look to be burning fine, no rust or oil contamination. looks like we might try to find a used engine, or rebuild one ourselves. the radiator is totally smoked, and the engine looks to have been cooked pretty badly. i found a master rebuild kit for 400 on line. it appears to have had a junkyard head put on the passenger side b4. new gaskets on the valve covers and manifolds. the van is real clean and well worth it, just not looking foward to doing it.
thx for the offer of your knoledge chuck! i got all the front end parts for the buggy.
all 35 spline now. just got get out and do it. got a dana 60 hub nut socket??
thx
Old November 23rd, 2009, 08:50 PM   #5
hamsmotorsports
ya i got that socket let me know we will get all the new parts put on
Old November 24th, 2009, 05:21 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
10/4 you da man!
Page generated in 0.28786 seconds with 41 queries
