sye - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2009, 01:35 PM   #1
roadtrip
roadtrip's Avatar
Default sye
looking for slip yoke eliminater kit with driveshaft used, 4.0 H.O. automatic trans is what I have Thanks
roadtrip is offline   Reply With Quote
Old November 22nd, 2009, 06:22 PM   #2
Fraser
Fraser's Avatar
people usually dont sell the sye used by itself, they sell the whole case. fyi.
Old November 22nd, 2009, 07:41 PM   #3
Medic8
You call, we haul.
Medic8's Avatar
You can get a new-ish setup from Ironrockoffroad.com for $225 shipped. It's a hack and tap kit (comes with yoke and a CV driveshaft).
Or, you can get a mainshaft/tailhousing replacement kit from jeeperz creeperz for $200, but then you have to buy a shaft to go with it.
Or, you can order a custom setup (rear section and CV shaft, to your spec) from Tom Woods for $370, plus $100 core, but you have to send them back your tailhousing and mainshaft.
Otherwise you probably won't find JUST a SYE kit, used.
Old November 22nd, 2009, 07:48 PM   #4
Fraser
Fraser's Avatar
Or, you can get the bottom section from Unlimited for the highlighted price, and still need a driveshaft. front xj shaft will work, cut it down or run as is depending on application
Page generated in 0.20371 seconds with 35 queries
