Turbo Supra r154? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2006, 03:11 PM   #1
PavementPounder
PavementPounder's Avatar
Default Turbo Supra r154?
First Gear: 3.250:1
Second Gear: 1.955:1
Third Gear: 1.310:1
Fourth Gear: 1.00:1
Fifth Gear: 0.753:1
This trans will mate to an AMC? The 1st gear is marginally less than a T-5, but I think the added strength would compensate with enough power and appropriate gearing on smaller rigs, like with up to 33" tires.
Anybody know anything about transfer-case compatibility, or is this just not a good candidate?
Old July 11th, 2006, 03:34 PM   #2
Well, is there a reason you want to know, like you already have one?
Its really no upgrade over an AX-15, they are more or less the same, I believe.. Strength differences are probably in the gearsets with the lower numerical gearing, like why a mustang T-5 is stronger than a Jeep t-5...
You can get the R151F behind the turbo 4 cyls, they are rare and expensive, or the R150 behind the V6 trucks.
The 151s use a gear driven t-case, so it accepts a doubler without additional adapters. The 150 uses a crappy chain drive t-case, so needs an adapter for the doublers..
BTW, supras also used a version of the AW4 auto...
Old July 11th, 2006, 03:45 PM   #3
PavementPounder
The guys on the AMC-List are an odd bunch that come up with interesting drivetrain combos for older AMC-cars.
The Jeep T-5 has numerically lower gearing than the Mustang T-5 in general, but there are versions out there that almost match the 4:1 Jeep ratio, like 3.9x:1.
You can get the R151F behind the turbo 4 cyls, they are rare and expensive, or the R150 behind the V6 trucks. The 151s use a gear driven t-case, so it accepts a doubler without additional adapters. The 150 uses a crappy chain drive t-case, so needs an adapter for the doublers..
The ratios I quoted refer to this trans specifically: This is a robust 5-speed transmission found in the MKIII Supra Turbo, the MKIV Supra (non-turbo) and Toyota Soarer (turbo) up to 2001. Wouldn't that be the trans used in the fast-as-hell twin-turbo (my friend has one), or was that a 6-speed?
BTW, Supras also used a version of the AW4 auto...
Yes, I knew about that. Its being talked about among the stroker people.
Old July 11th, 2006, 04:17 PM   #4
Ahh, if its in a car, yeah, probably could get an AX-15 bellhousing, I think, and bolt it on. One with an external slave would be nice.
Of coruse, the fastest supras are ditching them and using TH400s.. If only the AMC guys had a TH400 case with the right pattern:tonka:
Old July 12th, 2006, 08:48 AM   #5
hunter2005
Hagger Whats Up Man.. Do You Know Anyone Thats Got A Ifs Lift Laying Around..looking For It For My Dd...tyler
hunter2005 is offline   Reply With Quote
Old July 12th, 2006, 10:11 AM   #6
PavementPounder
Hey, what's up man? There\\\\\\\\\\'s one right here.
Old July 12th, 2006, 10:25 AM   #7
Hunter... no, don't know of anyone with an IFS setup.
Me, I'm just trying to get ready to build my Jeep....
Page generated in 0.18377 seconds with 44 queries
