Cheap way to install pwr steering on 4cyl cj - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2009, 11:48 AM   #1
peg
Default Cheap way to install pwr steering on 4cyl cj
I have an 81 cj, Looking for cheap ways to put power stearing on it. It has the old GM 4 cyl, also known as the iron duke. Thanks
ryan_fettig@hotmail.com
peg is offline   Reply With Quote
Old November 17th, 2009, 11:59 AM   #2
PavementPounder
PavementPounder's Avatar
I reported your post so that it would get moved to the Wanted Forum.
If you accidentally post in the wrong area in the future, click this button in you rpost and ask a Moderator to move it:
Simplest way to add P/S to the motor would probably be to hit the junkyard for the assembly off an Iron Duke-powered car and then buy the CJ lines. I have the box & pitman arm, and Jeepaholic has the steering shaft you need.
Old November 17th, 2009, 01:00 PM   #3
special k
special k's Avatar
i have a 89 yj 4 cyl powersteering gearbox if that will work
Page generated in 0.15307 seconds with 32 queries
