98 XJ Build *9"/D44*Cage*Meb Alls* - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2009, 05:20 PM   #41
curbdog17
Mini Van
curbdog17's Avatar
I got a little work done to day.
Swapped out the spindals and brakes to a 5 lug set up.
then I ripped it all back apart.(I only installed the 5 lug stuff so I knew it would fit)
Then I started to pull the knuckles
But I gave up on the drivers side.(I will finish it sunday)
I think I might replace the u-joint sunday too
Old November 28th, 2009, 06:42 PM   #42
4Bangler
Jackstand Wheeler
4Bangler's Avatar
You might want to re-think that, the 1/2 ton calipers won't clear the 3/4-ton knuckles, and those dual-piston 3/4 ton calipers won't fit in a 15" wheel if the backspacing is more than 2 1/2" ish. You're going to need F-150 knuckles to use the F-150 hubs, rotors, and calipers. If you were planning on running Hysteer, you'll need Chevy/Jeep flat-top knuckles and small bearing spindles to run that stuff
Old November 28th, 2009, 07:28 PM   #43
curbdog17
Mini Van
curbdog17's Avatar
I was informed that the 1/2 ton stuff would clear it. I will have to get some 1/2 ton calipers and find out. Thanks for the heads up.
I hope your wrong.
Old November 28th, 2009, 07:49 PM   #44
MiNi Beast
MiNi Beast's Avatar
I hope your wrong.
I got cores if you need them.
Old November 28th, 2009, 07:52 PM   #45
curbdog17
Mini Van
curbdog17's Avatar
I do thank Roger. can I get them now?
Old November 29th, 2009, 03:57 PM   #46
curbdog17
Mini Van
curbdog17's Avatar
Well I would like to start off with SHIT! FUCK! DAMB IT!
My brakes dont fit.
The good news is that it looks like there is room to make them fit.(just a little grinding)
I got the brackets cut off the D44 today.
Then I got things cleaned up.
I took the u-joints out today too
I will never get used to the bang they make when they come out. they shot out at my wall like a gun.
Im going to put these in Wed.
After the pain is dry.
Old November 29th, 2009, 04:09 PM   #47
MiNi Beast
MiNi Beast's Avatar
why man why? You should of got the spicers even with stock shafts, when those joints fail you risk the chance of taking out the shaft ears. You want those non greasable spicers joints. Like $30 a pop but worth it.
Old November 29th, 2009, 04:29 PM   #48
curbdog17
Mini Van
curbdog17's Avatar
When these brake I will have a reason to upgrade shafts and u-joints. I blew out the spicer in my D30 (same size joint 297) And replaced it with these and they seem to be holding up fine.
But good lookin out
Old November 29th, 2009, 06:31 PM   #49
Tacker
Tacker's Avatar
Looks like shit! Keep up the good work Jackass .
Old November 29th, 2009, 08:28 PM   #50
blue thunder
blue thunder's Avatar
I agree with mini beast on the spicers. I just did mine last night there alot bigger and stronger than the garbage gmp one i was going to put in there.
I got mine at bronco graveyard in brighton they were 25 bucks a peice
what are you doing for suspencion on the d44 coils,truss,and long arm?
blue thunder is offline   Reply With Quote
Old November 30th, 2009, 07:23 AM   #51
curbdog17
Mini Van
curbdog17's Avatar
Coils and a 3 link (Im goin to have Rich *4byfours*) do the front suspention.
Old November 30th, 2009, 07:51 AM   #52
curbdog17
Mini Van
curbdog17's Avatar
Thanks Terry
Old November 30th, 2009, 08:06 AM   #53
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
"Joe-Nan The Barbarian"
This cracks me up every time I see it!
The build is coming along nicely, keep up the good work.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old December 12th, 2009, 07:44 PM   #54
curbdog17
Mini Van
curbdog17's Avatar
Well I put the new U-Joints in
Then I put the knuckles and brakes together(with the 5-lug stuff)
Now I need to get some more parts $$$ together. Then I can continue building the front Axle.
Old December 13th, 2009, 01:10 AM   #55
tburda
tburda's Avatar
wtf? why are your needle bearings everywhere after taking the ujoint apart? lol i've never had more than one or two bearings fall out when changing ujoints.
tburda is offline   Reply With Quote
Old December 13th, 2009, 01:49 AM   #56
boggin-machine
boggin-machine's Avatar
x2
i have never used a press either.
Old December 13th, 2009, 10:30 AM   #57
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by boggin-machine View Post
x2
They were so rusty when they came out the caps broke and shit when all over. I think they were the original ones from 1979. I used the Ball joint removal tool from AutoZone. Its alot nicer that a big socket and the vise. (IMO)
Old December 13th, 2009, 03:32 PM   #58
MiNi Beast
MiNi Beast's Avatar
Awesome, I search "what a blast" and your thread is the first one that pops up!
So it's looking good. I need to get rolling on mine and catch up.
Old December 13th, 2009, 06:45 PM   #59
curbdog17
Mini Van
curbdog17's Avatar
If you can catch up
Old December 13th, 2009, 06:53 PM   #60
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
you.. i really need to get going on mine to get caught up lol oh by the way it looks good joe..
Page generated in 0.43539 seconds with 83 queries
