98 XJ Build *9"/D44*Cage*Meb Alls* - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2010, 10:11 PM   #181
curbdog17
Mini Van
curbdog17's Avatar
I cleaned out the garage today and have my D44 back from Rich, with the 5.38 gears installed. I will be putting that axle back together soon. I dont know what Im going to do for tires yet. I cant afford th Irok's so I may be doing something else for now at least 35's though. I will post some picks when I get going on the axle assembly.
Old June 4th, 2010, 01:08 PM   #182
drew91xj
drew91xj's Avatar
5.38....i thought my 5.13's were going to be high whats the finale tire size you plan on running?
Old June 4th, 2010, 08:54 PM   #183
curbdog17
Mini Van
curbdog17's Avatar
36-37 inch, I dont drive it on the road and plan to leave the TC stock gearing.
Plus I have an OD trans. I should be OK
Old June 4th, 2010, 09:11 PM   #184
blue thunder
blue thunder's Avatar
you already cut fenders so go with 37s or 38s
blue thunder is offline   Reply With Quote
Old June 4th, 2010, 09:17 PM   #185
curbdog17
Mini Van
curbdog17's Avatar
I will keep cutting more if I need to make them fit. I dont want any more lift.
Will probably go with 37. I was thinking about the 36" Irok It taller than the 37" Irok.
Old June 4th, 2010, 10:02 PM   #186
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
how about a 38 bogger ? have a set ill sell ya cheap..
Old June 5th, 2010, 01:00 PM   #187
drew91xj
drew91xj's Avatar
yeah i guess that makes sense i have the same basic plan but will probly stay with the 36 iroks you mentioned...unless i have room the cutting already done on mine so y not sill the gap with rubberlol
Old June 6th, 2010, 12:10 PM   #188
blue thunder
how much lift are you going to have when its all done with the axles and all
Old June 6th, 2010, 12:46 PM   #189
curbdog17
Mini Van
curbdog17's Avatar
about 6-7 inches of lift and alot of cut fender.
I plan to do some work on it Monday I will post up some pics then.
Old June 7th, 2010, 06:10 PM   #190
curbdog17
Mini Van
curbdog17's Avatar
So today I changed the fluid in my TC and found a small hole in my radiator, I put some of stop leak crap in there and let it run for an hour in my drive way with no leak and no over heating.
Then I went into the garage and tried to get motivated on the D44
5.38's installed
I put the outers back on and the shafts in
And I remembered to use antiseize too
So the 44 is back together now
And the 9" too
I need to get some new tires and put this shit under the jeep.
Old June 7th, 2010, 06:23 PM   #191
drew91xj
drew91xj's Avatar
what brackets are you going to use for the front buying them or making your own
Old June 7th, 2010, 06:31 PM   #192
curbdog17
Mini Van
curbdog17's Avatar
Rich is going to make them I think. He will be putting the front axle in for me I will be doing the rear my self.
Old June 7th, 2010, 07:02 PM   #193
drew91xj
drew91xj's Avatar
oic sounds like a good idea i bought the ballistic fab one and had tony rotate them 10* up and then had to add tnt high steer track bar... hine site is 20-20 i guess should have went with rustys coils and pieced it together or went all out with the tnt truss system symplicity would have been nice
Old June 8th, 2010, 12:10 AM   #194
creeping death
I'm that guy.
creeping death's Avatar
yes sir, you do!
looks good, Joe.
Old July 6th, 2010, 05:36 PM   #195
curbdog17
Mini Van
curbdog17's Avatar
So today I went to the junk yard looking for an electric fan for my XJ. mine has been off the jeep for some time. I could not find an XJ fan but I bought some other fan instead.
I set it up as a pusher to move cool air from the outside past the radiator.
Old July 6th, 2010, 07:35 PM   #196
drew91xj
drew91xj's Avatar
looks good whatdid you pull it out of?
Old July 6th, 2010, 09:44 PM   #197
curbdog17
Mini Van
curbdog17's Avatar
I have no idea, it was laying in a pile of fans. It was one of the thinner one in the pile. I wanted to mount it as a puller like the factory fan but this one is a little to large to fit on the inside.
Old July 9th, 2010, 02:03 AM   #198
creeping death
I'm that guy.
i got my fan from the junk yard too. i pulled it out of a dodge mini van. $5
Old July 27th, 2010, 08:53 PM   #199
curbdog17
Mini Van
curbdog17's Avatar
The fan worked great on our trip to the Cliffs and Badlands.
I have parts going out and some $$ comming in so I hope to get started on the axle swap soon.
Here is how the jeep sits now.
I have broken the back window and pass side rear window. So I just pulled the driver side rear before it broke too.
Should have more updates this weekend.
Old July 28th, 2010, 06:05 PM   #200
curbdog17
Mini Van
curbdog17's Avatar
So I pulled the rear axle today
Page generated in 0.43122 seconds with 83 queries
