CJ axles - built or Waggy Dana 44 front, pass. diff. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2009, 06:32 PM   #1
bigjeep65
Lurker
bigjeep65's Avatar
Default CJ axles - built or Waggy Dana 44 front, pass. diff.
Somebody must be upgrading their dana 44's for 60's, since we all know 60's are better. So, who has a set of axles coming out that are for sale. Looking for 44 front, to fit a CJ without outboarding the springs. Model 20 or 44 rear, prefer one piece shafts and trussed. Will be spring under with 33" or smaller tires. No need for 60's - too big and heavy for my use.
or
Looking for a front dana 44, i believe '75-'79 wagoneer. Will be narrowing for a CJ, to match wide track width.
Will take either a stock unit, or one already narrowed.
If stock, will also be looking for someone to narrow axle.
Thanks
Last edited by bigjeep65; November 21st, 2009 at 08:26 PM. Reason: changed title for more hits
bigjeep65 is offline   Reply With Quote
Old November 16th, 2009, 12:41 AM   #2
orangepile
orangepile's Avatar
Don't know how much your looking to spend but I have one that's completely rebuilt with 4.56 gear and ARB. $1100 and I'll narrow it for you.
orangepile is offline   Reply With Quote
Old November 16th, 2009, 08:08 AM   #3
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
Jeepaholic has got one already narrowed in the for sale section.
BeaverTown is offline   Reply With Quote
Old November 16th, 2009, 08:33 AM   #4
PavementPounder
PavementPounder's Avatar
You mean the one in the Completed Sales forum?
Old November 16th, 2009, 08:54 AM   #5
bigjeep65
Lurker
bigjeep65's Avatar
Orangepile - More than I originally wanted, but I would put that much into one to get it to that point I'm sure. What are you running on it for outers and steering? I had planned on ending up with a 5x5 1/2, chevy calipers, ford rotors. Not 100% on the knuckles, don't necessarily need high steer since this one is spring under. What are you running out back to go with?
Beavertown - Yeah, I missed that one. Was working on the trans. conversion at the time.
It's all about the timing.
Old November 16th, 2009, 09:04 AM   #6
BeaverTown
Cuck Fancer
BeaverTown's Avatar
OOPS, sorry.
Old November 16th, 2009, 10:35 AM   #7
orangepile
orangepile's Avatar
It's got the stock outers on it.
Old November 17th, 2009, 06:11 AM   #8
bigjeep65
Lurker
bigjeep65's Avatar
Any other options available?
Orangepile - Still considering yours, top end of the budget, and will still need to convert the lug pattern.
Old November 17th, 2009, 08:21 PM   #9
J Truck Rick
J Truck Rick's Avatar
I have a couple here,they are from wide track Cherokees,though. But since you are narrowing it it shouldn't matter.
J Truck Rick is offline   Reply With Quote
Old November 18th, 2009, 03:42 PM   #10
bigjeep65
Lurker
bigjeep65's Avatar
J Truck Rick -
I'll keep that in mind, will have to look at the rear axle options if I go that way. If I've done my homework right, I could narrow the long side by ~4 inches to bring the spring pads into cj width. On the wide track that should bring the overall width wms to wms to 61". I was actually shooting for around 56"
I could narrow the other side as well, more cost and a second shaft.
What price range are we talking?
Thanks,
Old November 21st, 2009, 08:27 PM   #11
bigjeep65
Lurker
bigjeep65's Avatar
bump -
Will also consider a set -
Old November 21st, 2009, 08:49 PM   #12
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
I got waggy 44s ft is narrowed to fit cj cut side uses a stock EB shaft. 410 gearing disk all around detriot in rear LS up ft. New bearings and seals in rear. Newer brakes all around. 6 lug pattern. $1000 obo
Old November 21st, 2009, 09:02 PM   #13
Trail Junkie
iamfawkinwithyou
Has 1 ton high steer also
Old November 23rd, 2009, 07:09 AM   #14
bigjeep65
Lurker
bigjeep65's Avatar
I'll PM for details.
Old November 23rd, 2009, 07:20 AM   #15
Silver93XJ
Silver93XJ's Avatar
Complete Axle(s): 1972 cj dana 44 with 3.73 - Great Lakes 4x4. The largest offroad forum in the Midwest
Silver93XJ is offline   Reply With Quote
Old November 23rd, 2009, 07:28 AM   #16
bigjeep65
Lurker
bigjeep65's Avatar
Thanks, I have one of these already, looking for widetrack width - front first or set.
Old November 23rd, 2009, 07:29 AM   #17
Silver93XJ
Silver93XJ's Avatar
ooops sorry!
Old November 23rd, 2009, 08:42 AM   #18
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I can build you whatever you want, hp30, dana 44, hp44 (was going to build me one of these)
Also have a set of alloy cj 30 stub shafts for the larger u joint for sale.
Old November 23rd, 2009, 09:16 AM   #19
bigjeep65
Lurker
bigjeep65's Avatar
I'll send you a PM on the axle part.
Would the stub shafts for the 30 work with a Superior Axle (uses the larger joint), can't remember if there were alloy's or not. Thinking that they were not, but can't find the info on the anymore.
I'll measure the one I bent the ears on.
Thanks
Old November 24th, 2009, 12:51 PM   #20
bigjeep65
Lurker
bigjeep65's Avatar
PM sent Jeepaholic
Tags
d44 front, pass drop
Page generated in 0.41561 seconds with 84 queries
