2006 Dodge Ram center dash panel removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 14th, 2009, 09:44 PM   #1
gmotox
gmotox's Avatar
Default 2006 Dodge Ram center dash panel removal
Any one know how to remove the center dash panel in a 2006 Dodge Ram? my heater control lights are not working and can't see any kind of obvious way to remove the center panel. It has floor mounted cup holders.
I think it would be the same procedure to remove radio if anyone has done that.. .
Thanks!!
Old November 15th, 2009, 03:29 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
you have to pull the complete lower center council were the cup holders are, take the panel off under the heater controlls, there are two screws behind that panel that hold the shroud for the radio/heater controlls on the rest of it clips in i believe
hamsmotorsports is offline   Reply With Quote
Old November 15th, 2009, 04:51 PM   #3
gmotox
gmotox's Avatar
Thank you for the input!! I will keep you posted if it works.
Old November 17th, 2009, 08:36 PM   #4
dline
dline's Avatar
should work, what he told you.
dline is online now   Reply With Quote
Old November 24th, 2009, 03:54 PM   #5
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
sounds right to me lol
muddy maki is offline   Reply With Quote
Old December 14th, 2009, 06:05 PM   #6
gmotox
gmotox's Avatar
Thanks everyone, the imformation was correct. first you need to remove the cup holders, then the lower piece in front of those, then the bottom center dash and then you can remove the two lower screws of the radio/heater bezel and then pull outward!
Page generated in 0.26453 seconds with 41 queries
