6.0, 5.3, Fuel pump? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2009, 08:32 PM   #1
somer1
You Get the Big One
somer1's Avatar
Default 6.0, 5.3, Fuel pump?
To the people running 6.0l or 5.3 , what fuel pumps and regulators are you running?
somer1 is offline   Reply With Quote
Old November 13th, 2009, 08:45 PM   #2
I got the OEM fuel pump module from the tank for my L33, I am planning a corvette regulator/filter, since my motor is returnless....
Old November 13th, 2009, 09:12 PM   #3
jeepm715
DEAK Racing
jeepm715's Avatar
I run a Carter inline pump on my 5.3, return line off the regulator on the fuel rail. Just make sure it has at least 60-80psi, theres usually only 3 choices. Low psi for carbs, mid for TBI systems, and high for multiport stuff.
Most of the truck motors run 2 lines with a regulator built into the fuel rail. If you don't have a built in Reg, the Corvette filter/reg is a good cheap solution. If you have a good local parts store, they have adapters to use the original fuel rail fittings and adapt them to hose or brake line.
jeepm715 is offline   Reply With Quote
Old November 13th, 2009, 11:05 PM   #4
somer1
You Get the Big One
somer1's Avatar
I have an 04' LQ9 for reference, I read on pirate that the newer motors don't run a return line? I haven't had a chance to check the motor for myself as I've been out of town. Do you happen to have a part/model #?
Old November 13th, 2009, 11:07 PM   #5
somer1
You Get the Big One
somer1's Avatar
What year corvette regulator, filter are you running? Just any LS1 year.
Old November 14th, 2009, 08:44 AM   #6
I think 1999+ will work, for the regulator.
lots of good info overall in these threads:
http://www.pirate4x4.com/forum/showt...829&highlight=
5.3 Jeeps - Pirate4x4.Com Bulletin Board
Old November 16th, 2009, 09:58 AM   #7
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I will be using the 99 truck oem pump, adapted to fit a yj tank.
RIP FULLSIZE4LIFE
SHARPMACHINE is online now   Reply With Quote
Old November 16th, 2009, 07:51 PM   #8
somer1
You Get the Big One
somer1's Avatar
Do you have to change any relays or fuses to run the stock in tank fuel pump, also what are you running for a fuel filter? Thanks.
Old November 17th, 2009, 07:10 AM   #9
SHARPMACHINE
F-U-CANCER!!!
If you are asking me?
I will be running a yj fuel filter (I think my frame is a 2.5 and has a frame mounted filter?).
As far as wiring, I will be adding the pump to a carberated pick-up and running my own wires to the tank, probably to the yj fuse box?
RIP FULLSIZE4LIFE
Page generated in 0.34389 seconds with 51 queries
