Spartans Lunchbox Locker - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2009, 06:22 AM   #21
IDIeselman
IDIeselman's Avatar
Hp 44 front, 9" rear, 35" boggers. Loc rights in both for 2 years now with no problems.
Old November 17th, 2009, 08:20 PM   #22
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Originally Posted by Fraser View Post
X2 to the similar design. from all that ive read the lunchbox type hold up to a shock load better then a detroit. in situations w/ rocks, 40" tires, and an I-6 w/ a doubler behind it.
Ya i've heard the same thing as well!
Old November 19th, 2009, 12:54 PM   #23
Curious to see how it will hold up. The pins give the impression of being larger then lockrights or Aussie. But the pins in fact are hollow. The the spot where the abuse will take place on the pins is the smallest diameter of the pin itself. The pins have a groove so you can hold the pin into the locker half when assembling it. Then once installed, you pull the pin and it releases the locking pin. The spring that holds the outward pressure in the locker is what sits inside the hollow pin.
Just finished install on a D44.
Old November 23rd, 2009, 08:27 PM   #24
joe_jeep
welfare wheeler
joe_jeep's Avatar
Originally Posted by Kodiak450r View Post
after owning a lunchbox locker and having it break within 3 weeks of installing it i don't think i'll ever own one again.
i had a detroit e-z locker in my dana 30 on my tj with 35's and then 36's for about 60,000 miles. never had an issue. mine was installed my a jeep tech i know and trust. its still in there being used today by the new owner. probably has another 10,000 miles on it by now.
it survived broken stub shafts on 2 different occasions. im sure some people do flog their vehicles harder than i do, but was used significantly. many w.o.t. assualts at the citadel. it has been all over drummond many times. done silver lake and the mounds many times. numerous trips to the u.p.
nothing is unbreakable, but i know alot of people using them with great results. perhaps you got a bad unit from the factory? defects happen?
perhaps it was just bad luck.
not that there is anything wrong with a detroit or a spool or even a welded carrier. to each there own.
Old December 29th, 2009, 06:09 PM   #25
Hoss Blazer
!SPARTY ON!
Anyone used a Spartan locker yet???
Page generated in 0.32681 seconds with 38 queries
