Mazza u joint press - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2009, 01:07 AM   #1
AZTEC
AZTEC's Avatar
Default Mazza u joint press
i took my half shafts to Mazza today to get them pressed out cause im a little lazy. but when i got home and tried to put in new u joint, it ended up being a little bent on the yoke so i was wondering if any has had this problem before? and where can i go to get a new halfshaft end that connects to the hub? please help i need to know asap.
thanks
AZTEC is offline   Reply With Quote
Old November 12th, 2009, 01:11 AM   #2
kj kyle
kj kyle's Avatar
a half shaft? did you put independent front suspension on your XJ?
I assume your talking about a stub shaft, which i garuntee people have D30 stub shafts everywhere... try the wanted section. or you could order some alloys.
kj kyle is offline   Reply With Quote
Old November 12th, 2009, 01:13 AM   #3
NSmist
NSmist's Avatar
Send a message via AIM to NSmist
Yeah, that's the part. The yoke into the hub assembly.
NSmist is offline   Reply With Quote
Old November 12th, 2009, 01:17 AM   #4
kj kyle
kj kyle's Avatar
Old November 12th, 2009, 01:24 AM   #5
NSmist
NSmist's Avatar
Yes, he's looking for the pass. stub shaft. Can probably just merge this into his WTB post.
passenger side half shaft dana 30! - Great Lakes 4x4. The largest offroad forum in the Midwest
Anyone ever have Mazza or another shop bend their yokes? I'm wondering if he can get anything out of them before he drops $20 on a new one. They pressed out the shafts that meet the diff first, so those are good, but bent the pass. side stub shaft in a hair so the inner depression on the cap doesn't show up.
Old November 12th, 2009, 06:54 AM   #6
kixx007
Certified Ypsilantian
kixx007's Avatar
There is a spec somewhere for the distance between ears. I don't remeber the website or where to get the info. However I have bent the ears on yokes myself before. It happens when you use a shop press to force them out.
Take a brass hammer and hit the ear until you are able to install the joint and get both clips on. Infact I bet if you take it back to them, they will do it for you.
kixx007 is offline   Reply With Quote
Old November 12th, 2009, 07:03 AM   #7
rentalrider
rentalrider's Avatar
Yeah, not sure if it's right or not, but I've bent one myself and had to correct it. It happens.
Old November 12th, 2009, 07:03 AM   #8
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
X2 I would definitely go back to them and kindly explain the problem. They should be able to correct it.
Old November 12th, 2009, 07:11 AM   #9
kixx007
kixx007's Avatar
I lied. Its 2.188" in between the ears. Vernier Caliper too measure it. Brass hammer to open it up if its under that number.
Old November 12th, 2009, 07:27 AM   #10
Tom
Because racecar
Tom's Avatar
Old November 12th, 2009, 07:38 AM   #11
silverxj
Recovering XJ owner
silverxj's Avatar
how bent? they will seem to flex some and you can probably get it to span back out by smacking the outside of the ears.
ok .. maybe I should have read the entire post...
Old November 12th, 2009, 09:13 AM   #12
skife
skife's Avatar
its metal, it bends.... bend it back.
Old November 12th, 2009, 09:39 AM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I don't even use a press on axle shaft joints anymore. Cut the cross out with the torch, and hammer the caps out one by one in the vice.
Saves the headache, and keeps the ears straight.
When we had a smaller press I never had the issue, if the joint didn't move I either wasn't pressing straight, or I needed to tap the shaft with a hammer. With a bigger press (20ton maybe) it doesn't care, it just bends the shit out of stuff.
JcrOffroad
Zoom Zoom!
Old November 12th, 2009, 09:41 AM   #14
Pokerob
hug life
Pokerob's Avatar
i have done that before, worked great. but man one popped so hard it scared the sh1t outta me
Old November 12th, 2009, 09:56 AM   #15
kixx007
kixx007's Avatar
x2 on the torches. I also found that an actual ball joint/u joint press tool works with less damage than a hydraulic press.
Old November 12th, 2009, 10:04 AM   #16
skife
skife's Avatar
mine we're orginals from 1991, 250k miles, pulled out the retainer clips on them, hit 'em with a hammer while in a vice a few times and they we're out, no need for a press.
Page generated in 0.48610 seconds with 71 queries
